Thread: My 98 pontiac gtp supercharger want stay started
Results 1 to 7 of 7
  1. #1 My 98 pontiac gtp supercharger want stay started
    Jun 2012
    Sacramento
    I have a 98 pontiac gtp supercharger.My car want stay started unless my foot is on the gas. The moment I take it off it dies. I just got a tune up, a brand new mass air flow sensor. A new battery. what could it be. Please help
  2. #2 Re: My 98 pontiac gtp supercharger want stay started
    I live here. TLSheff's Avatar
    Could be a number of things.
    I say start with checking for a vacuum leak. Some ThrottleBody/Starting Fluid/Injector Cleaner spray would be needed, you spray all the connecting points on the vacuum lines 1 by one. If at any point spraying a piece causes the engine RPMS to rise then that area has a leak. I understand this would be difficult in this circumstance, may require the use of a helper to hold the rpms at a low rpm without bouncing too much or letting the car die.
    Also if you could answer these questions it would help greatly.
    Was the problem happening before or after you did the tune up and bought the new MAF Sensor?
    Had you performed any work on the car immediately prior to it having problems?
    When you hold your foot on the gas and keep it running, does it have a CEL (Check Engine Light) on?
    - If it does have a CEL: Have you scanned for the codes? If yes, what are they?
    What all did you replace/change while performing the tune up?
    When was the last time you replaced the Fuel Filter?
  3. #3 Re: My 98 pontiac gtp supercharger want stay started
    Jun 2012
    Florida
    check the fuel pump relay switch
  4. #4 Re: My 98 pontiac gtp supercharger want stay started
    Jun 2012
    Sacramento
    I went to get the codes pulled and this is what came up p0102a (mass air flow sensor circuit low frequency) p1671 driver line 4 p1672 low oil level lamp control ciruit. I got a tune and a new mass air sensor. I started having this problem after i got my car alarm hook up
  5. #5 Re: My 98 pontiac gtp supercharger want stay started
    Might have blown the maf fuse under the hood. I can't remember the number but it says IGN something. Check that out. Sounds like you have some bad wiring somewhere.
  6. #6 Re: My 98 pontiac gtp supercharger want stay started
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  7. #7 Re: My 98 pontiac gtp supercharger want stay started
    Out West
    Want or wont.
    Whine with your Cheese?
  1. 2000 pontiac grand prix gtp supercharger
    By dwinter in forum General Grand Prix Discussion
    Last Post: 06-09-2012, 09:54 PM
  2. New fuel filter today and now car wont start/stay started
    By spider4 in forum General Tech Discussion
    Last Post: 01-04-2012, 10:50 AM
  3. Doesn't want to stay started
    By penguinknot in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-13-2011, 10:48 AM
  4. Can't get the car to stay started at operating temp.
    By afallucco in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2010, 10:20 AM
