Thread: oil pressure sensor
Results 1 to 11 of 11
  1. #1 oil pressure sensor
    Jun 2012
    I have a 1999 Grand Prix GTP with an aftermarket oil pressure gauge. I want to get an oil pressure sensor so i can monitor the oil pressure with the gauge. All it has right now is the oil pressure switch. What kind of oil pressure sensor do I need to get?
  2. #2 Re: oil pressure sensor
    I bought this gauge.
    Tinted 7 Color Oil Pressure Gauge
  3. #3 Re: oil pressure sensor
    the gauge comes with the sensor. it screws in place of the stock oil pressure sensor.
    most auto parts store sell the kit for 50 or less. get a electrical one, not a mechanical pressure, thats the one with the plastic tubing.
    if you bought the car like this, check the wire from the sensor to the gauge, it could have gotten burn or broke somehow, or the power is not hooked up.
    the sensor is located by the oil filter.
  4. #4 Re: oil pressure sensor
    Jun 2012
    I bought the car as is. I noticed it had an oil pressure gauge but it didn't read anything. So i did a little investigation and found out the guy who had it before me didn't even try to hook it up to a pressure sensor. I found where the pressure switch is and it looks like it hasn't been touched. Does anyone have any ideas where I can get a sensor for it?
  5. #5 Re: oil pressure sensor
    From....the gauge's manufacturer Seriously..I'd see how much the part is vs a whole new gauge.
  6. #6 Re: oil pressure sensor
    Jun 2012
    What I meant was I bought it as it is now from the guy before me. It wasn't from a dealer... unfortunately.
  7. #7 Re: oil pressure sensor
    a dealer wouldn't fix that, its after market, the new gauge kit is the way to go. internet or parts store. you can get 2 and 3 gauge kits with mounts on the net.
  8. #8 Re: oil pressure sensor
    Jun 2012
    How do I know if i get a new gauge for it that the oil pressure sensor will work or be accurate?
  9. #9 Re: oil pressure sensor
    You mean the sensor on the old gauge?
    Is this an electric guage, if not..it's a fitting and a tube.
  10. #10 Re: oil pressure sensor
    Jun 2012
    It's an electric guage
  11. #11 Re: oil pressure sensor
    on the face of the gauge it should say who makes it. they try googling who makes it, see if you can buy just the sender unit for it.
    any gauge you get will be accurate, more so than no gauge at all, at least you will learn where it should be cold, warm, and when your a quart low on oil too.
  1. Oil Pressure Sensor
    By confused in forum General Tech Discussion
    Last Post: 02-18-2012, 03:07 PM
  2. RR tire pressure sensor problems
    By guyonsomecouch in forum General Tech Discussion
    Last Post: 12-18-2009, 11:30 PM
  3. 2001 Grand Prix A/C Pressure Sensor
    By Bartbk02 in forum General Tech Discussion
    Last Post: 07-07-2009, 10:34 PM
  4. Tire Pressure Sensor
    By DduBBs08GP in forum General Tech Discussion
    Last Post: 11-27-2008, 11:15 AM
  5. Oil Pressure Sensor
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2008, 12:11 PM
