Thread: Help On Clunking Noise In Rear Side
Results 1 to 3 of 3
  1. #1 Help On Clunking Noise In Rear Side
    Jun 2012
    Maine
    I bought my 2000 Grand Prix GTP in January and the mechanic who inspected it said that I have a clanking noise in the right rear side and that I would need to get a new strut in about a year. The clanking noise is very annoying and it seems its coming from the right rear side. It clanks when I go over any bumps or uneven ground, also if I am breaking/driving slowly. Well two weeks ago my left rear strut gave out so I found a new mechanic and he replaced my two rear struts and mounts and got all my tires replaced. I got my car back yesterday and drove it around for a bit and its still clanking although I replaced my struts and mounts. So I have been doing research and found a couple things it could be:
    • Worn sway bar/bushings/links
    • Control Arm
    • Heat Shield
    • Loose Exhaust hanger
    • Mount plate
    So those are some of the things I have found. I have a feeling it has to do with my sway bar but I just need to get this figured out. Yesterday I checked if my wheel baring was loose or broken but its not. Any ideas?
  2. #2 Re: Help On Clunking Noise In Rear Side
    Possible sway bar links, could be trailing arms aswell.
  3. #3 Re: Help On Clunking Noise In Rear Side
    Jun 2012
    Maine
    Thank you. I was thinking it was the sway bar links as well. I am putting it on jack stands tomorrow and I am going to look at it. It's such an annoying sound.
  1. clunking raddleing noise in rear with vid
    By gtcoup in forum Brakes/Suspension/Chassis
    Last Post: 03-05-2012, 10:10 PM
  2. clunking noise
    By jessejj79 in forum General Tech Discussion
    Last Post: 02-28-2011, 12:49 PM
  3. Clunking Noise...
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 01-10-2011, 09:17 PM
  4. Bad clunking noise and bad acceleration
    By ill12will8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2010, 03:00 PM
  5. clunking noise?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-07-2009, 02:55 AM
