Thread: I love my new car but
Results 1 to 7 of 7
  1. #1 I love my new car but
    May 2012
    kent ,washington
    Two weeks after buying a car It is now overheating at Idil. I put in 180° thermostat And also flush the system. Still day is over heating thing at Idil And I don't know what to do so if anybody can help me out with thing I would appreciate it
    SE Level Member Dthreap's Avatar
    ohio
    Did you bleed it?
    Sent from my HUD.
  3. #3 Re: I love my new car but
    May 2011
    Kansas City
    next question.....did you replace the coolant temp sensor?
    Reptile Tune (SOLD)
  4. #4 Re: I love my new car but
    The Boss Iceman6669's Avatar
    Jun 2011
    plugged Radiator
    plugged hose
    plugged heater core
    BAD coolant leak
    2011 F-150 Yote powered
  5. #5 Re: I love my new car but
    May 2012
    kent ,washington
    I did bleed it and have not yet changed tcs but have it on hand. From what I understand there's two phases of fan speeds. From what I understand the fan one relay in the under hood fuse block Controls the low speed fan. My fan doesn't turn on untill the temp on the guage is 3/4 of the way up.
  6. #6 Re: I love my new car but
    HUDSON
    If you could clarify to what you consider "overheated"
    If your cooling system has no air in it, and it has no leaks, fans woorking properly, it is not uncommon to see 220f at low ground speed or sitting still.
    If it's not showing in the red zone on the gauge, it's ok. But it is a good thing that you take notice to the rising temp, it is just a fact that these car are designed to run
    hot, epecially at low speed to reduce emmisions.
  7. #7 Re: I love my new car but
    Texas
    If the needle is in the red and you have checked everything else look to a possible cylinder head crack. My buddies GTP had a hairline crack between 4 and 6. Infact we spent days looking at everything else. We finally pulled the heads and took them to the machine shop. Replaced the head that was cracked and all is well.
    85 Corvette
    01 TA
    03 Z06
  1. I love these!
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 08-23-2011, 06:41 PM
  2. Love The Forum Love Pontiacs
    By neverforgetpontiac in forum Introductions/Noob Questions
    Last Post: 04-08-2011, 01:26 PM
  3. i love my job :)
    By gtpinsc in forum Off Topic Discussion
    Last Post: 11-05-2009, 12:24 AM
  4. i love gpf...
    By 2000GTP in forum Off Topic Discussion
    Last Post: 01-25-2009, 05:05 PM
  5. 9c1 love
    By Sinister Drag Designs in forum Off Topic Discussion
    Last Post: 12-18-2007, 05:54 PM
