Thread: One man, many issues
Results 1 to 10 of 10
  1. #1 One man, many issues
    May 2012
    Indy
    I have a 99 gp gt and i have some serious electrical issues...i have done very little to it yet, many plans though. So heres whats goin on, a week ago my window regulator broke on the drivers door which i replaced, and now my cars haywire. First off the car wont start, ill get one click of the starter then nothing. I checked the voltage on the battery with my multimeter and its at 9.4volts. I attempted jumping it nevertheless, nothing. My key locks in the ignition and most of the power to the cabin cuts out. Doors dont ding, windows wont roll, radio wont play, and the dome lights become strobes...i looked all over and cant find a fix for it, i also tried disarming with no avail, if any knows something to try please help! Thank you!
  2. #2 Re: One man, many issues
    Houston
    9.4 volts is one dead battery, man. Charge it up or replace it. It should read around 12.6 volts.
  3. #3 Re: One man, many issues
    May 2012
    Indy
    I had it hooked to the womans mountaineer for a while, and nothin
  4. #4 Re: One man, many issues
    Houston
    Its too far gone for a jump. 11.7 Volts is 0% charge. Completely dead. You are well below that. You need a battery charger or a new battery.
  5. #5 Re: One man, many issues
    May 2012
    Indy
    Ill take it to autozone but id thats the prob, it was just fine the day before
  6. #6 Re: One man, many issues
    May 2012
    Indy
    Idt*
  7. #7 Re: One man, many issues
    Houston
    If you are only reading 9volts.....that is your problem.
  8. #8 Re: One man, many issues
    May 2012
    Indy
    Will that lock the key in the ignition and all the other stuff??? Cuz that would b friggin amazing!!!
  9. #9 Re: One man, many issues
    Houston
    Yep. You can unlock the key. There's a circle access panel on the bottom of the steering column (below where you put the key in). Just remove that and stick a small screw driver in there and it will release. Or you might be able to pull enough voltage off of the mountaineer to release it. Right now, you are trying to run a 12v system off of 9volts. Replace or charge the battery and you're up and running.
  10. #10 Re: One man, many issues
    May 2012
    Indy
    Thanks for the advice Keith, shes bangin like a champ now!!! Also finished the window repair, all in all a good day!
  1. MAF issues?
    By Sl33p3rGt in forum General Tech Discussion
    Last Post: 07-18-2011, 05:40 PM
  2. Just got a 98 GTP has issues lol
    By beno420 in forum Introductions/Noob Questions
    Last Post: 05-17-2011, 10:14 PM
  3. Any issues?
    By BwolfGT in forum Off Topic Discussion
    Last Post: 12-27-2009, 06:42 PM
  4. A few issues
    By Ellen in forum General Tech Discussion
    Last Post: 09-17-2009, 09:29 AM
  5. 05' gp gt issues!!!! - please help!!
    By Billyb in forum General Tech Discussion
    Last Post: 05-17-2009, 09:20 PM
