Thread: 1994 Grand Prix SE Diagnostic codes
Results 1 to 5 of 5
  1. #1 1994 Grand Prix SE Diagnostic codes
    Apr 2012
    Central Florida
    Hi everyone, just signed up on this forum today. On Tues I brought my car to a service center which did free diagnostic code reading and found out the following codes were in the computer memory.
    Codes present:
    13 - O2 sensor circuit open, shorted, or bad
    14 - Coolant temp signal low or shorted
    15 - Coolant temp signal high or open
    21 - Throttle PS / current high
    33 - MAP sensor or circuit to high
    34 - MAP sensor or circuit to low
    36 - IC 24X signal error
    41 - EST line Error
    42 - Bypass line Error
    44 - Lean Exhaust
    45 - Rich Exhaust
    51 - ECM Prom error
    54 - Fuel pump voltage too high too low
    86 - Internal ECM problem (A/D) error
    99 - Power Management
    He also said this car has "History Codes" which are as follows:
    34 - MAP sensor / circuit problem
    66 - A/C pressure sensor / circuit problem
    70 - A/C pressure sensor too high
    75 - EGR solenoid 1 problem
    76 - EGR solenoid 2 problem
    77 - EGR solenoid 3 problem
    I bought the car for $350.00 form my neighbour who only put around 10,000miles in the last 3 1/2 years. At time of purchase we were told that my car was owned by an 18 y.o. person who might have driven the car hard (setting some of the codes on it). The car runs great even though it has all those codes on it. Is there anyone who is a mechanic out there that can explain these codes to me so I can get a better understanding of my car.
    Thank you
  2. #2 Re: 1994 Grand Prix SE Diagnostic codes
    GTP Level Member Rico's Avatar
    Apr 2009
    Fort Worth TX
    You need to start from scratch. Have all codes erased and then drive for about 100 miles. Scan again.
    It's a CUMMINS Dodge not a Dodge Cummins
  3. #3 Re: 1994 Grand Prix SE Diagnostic codes
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  4. #4 Re: 1994 Grand Prix SE Diagnostic codes
    Apr 2012
    Central Florida
    ok ty 1ATONY, I will go back and see about having the codes erased .... by the way do you know of anyone who has an OBD1 reader specific to my car ... My ALDL connector only has 2 wires ... the terminal "A" & "M". I cant afford too much so a good deal would be appreciated!
  5. #5 Re: 1994 Grand Prix SE Diagnostic codes
    Apr 2009
    Fort Worth TX
    You can jump the two terminals with a paper clip and get the codes by counting the SES flashes. Do a Google search on it. There's tons of info available.
  1. New 1994 grand prix se owner Nj
    By jrzygp in forum Introductions/Noob Questions
    Last Post: 05-05-2012, 12:19 AM
  2. Looking for a exhaust 1994 Grand Prix SE
    By FrankB in forum General Tech Discussion
    Last Post: 04-09-2012, 05:49 AM
  3. Pulling codes 1994 GTP 3.4
    By Teardrop in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-27-2010, 11:47 PM
  4. 1994 Grand Prix - Limp Mode
    By TexasSteve58 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 05-16-2010, 06:31 AM
  5. 1994 Grand Prix Transmission Help!
    By mfalk22 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-25-2008, 11:41 AM
