Thread: noises!
Results 1 to 8 of 8
  1. #1 noises!
    GT Level Member JesseBranham's Avatar
    Apr 2012
    Myrtle Beach, SC
    there is this noise coming from the front and it sounds like "E E E E E" but it goes away if you mash the brakes. Any ideas to what it is? also there is a scraping noise if you turn the wheels to the right.
  2. #2 Re: noises!
    Have you checked your brakes at all? Also possibly a wheel bearing.
  3. #3 Re: noises!
    Charles City, IA
    Sounds like your pads are down to the squealer.
    SMGPFC Two Nipple General
  4. #4 Re: noises!
    Apr 2012
    Myrtle Beach, SC
    we replaced all of the brakes all the way around and the front right wheel bearing too.
  5. #5 Re: noises!
    Did you bend the dust shield when doing the brakes? It could be hitting and dragging a little bit.
  6. #6 Re: noises!
    Apr 2012
    Myrtle Beach, SC
    I dont know. Ill have to check that out tomorrow. thanks!
  7. #7 Re: noises!
    I did that when I put my trailing arm on and it took me a little while to figure out what it was.
  8. #8 Re: noises!
    Apr 2012
    Myrtle Beach, SC
    Found It! It was the slides on the brakes (the place you slide in and out the brakes). The brake pads we moving and causing a squeaking noise.
  1. popping noises
    By Jakegday in forum General Tech Discussion
    Last Post: 08-16-2011, 06:40 AM
  2. Creaky noises...
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2011, 11:47 AM
  3. noises...
    By mousemonster1232 in forum General Tech Discussion
    Last Post: 01-23-2011, 04:14 PM
  4. Rattling noises
    By Ramond in forum Introductions/Noob Questions
    Last Post: 09-19-2010, 12:47 PM
  5. K&N Air Intake noises
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 10-19-2008, 09:07 PM
