Thread: tranny in a 2001 gtp
Results 1 to 6 of 6
  1. #1 tranny in a 2001 gtp
    Mar 2012
    wantagh ny
    im a new owner of a 2001 gtp and the tranny just went on it. i was wondering if the cars have a problem with going through transmissions, i also plan to put alot of mods into it and boost the power. so i was just wondering if this would be a good idea with a stock transmission because i cant afford another one anytime soon?
  2. #2 Re: tranny in a 2001 gtp
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    http://www.grandprixforums.net/safel...car-17482.html
    start here ^
    they tend to be weaker, but you probably will be fine
    just dont flooring while turning
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  3. #3 Re: tranny in a 2001 gtp
    HUDSON
    If you cant afford transmission repairs, than it would be a good idea to drive conservative with it, no burnouts or hard launches. Even normal use can take its toll on a stock transission with lots of miles. Keep the fluid under normal temperatures, regular maintanace with filter and fluid change can help.
  4. #4 Re: tranny in a 2001 gtp
    Mar 2012
    wantagh ny
    well i have a brand new transmission in it with only 2000 miles now but its a regular run of the mill transmission and im a 19 yr old kid i do have a tendency to beat on it to show off, im just wondering if it will last at least 2 or 3 years when i can afford a better one. i also want to get my GTP to have like 300hp and like 350lbs of tourque will the tranny be able to handle this?
  5. #5 Re: tranny in a 2001 gtp
    Nov 2010
    Maryville, MO
    id start with basics; headers, 3.4 pulley, tune, and intake
    the tranny should hold that power fine and then if your still looking for more power go from there.
    // 2005 Comp G
  6. #6 Re: tranny in a 2001 gtp
    It'll hold up to 270-280 CHP fine for a long while. Once you hit the 300 CHP I'd say the trans is on borrowed time if you like romping on it. But who knows, maybe it wont break for a long time or maybe it will.
  1. 2001 GTP tranny fluid leak
    By pcengine92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-24-2012, 02:19 PM
  2. 2001 GTP SE Front Fender same as 2001 GT
    By BrentHamm in forum Visual/Body Modifications
    Last Post: 12-19-2011, 05:22 PM
  3. 2001 gp
    By 01GrandPrixGT in forum Members Rides
    Last Post: 10-28-2011, 04:58 PM
  4. 2003 gp gt tranny on a 2001 gp gt?
    By schmitt55 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-24-2010, 08:26 PM
  5. 2001 GTP Trans into 2001 SE?
    By TechSmurf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2009, 07:11 PM
