Thread: Heat Actuator
Results 1 to 3 of 3
  1. #1 Heat Actuator
    Mar 2012
    Stockton,Ca.
    My wife has a 2000 Grand Prix and when she turns on her air the driver side gets cold air but the passengers side gets warm air? How can I check the passenger side actuator?
  2. #2 Re: Heat Actuator
    Mar 2012
    I just joined the forum today, and having some similar issues to this. Do some forum searching first, there are a lot of threads about this with solutions already discussed. Good luck!
  3. #3 Re: Heat Actuator
    remove the glove box, to your left on the side of the air box, you will see one of these. its called a blend door actuator. this is not your part don't buy it, but it looks just like it. OEM CHEVY GMC TRUCK HEAT HEATER A/C FAN Air VENT BLEND DOOR ACTUATOR 16177412 | eBay
    its got 2 screws and a plug on it. remove it and turn the knob by hand to cold air, and then buy a new one and install it the reverse you got it out.
    oh you have one on the other side as well, for dual climate control.
  1. Supercharger ACTUATOR???
    By PTGsDaytona500GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2012, 08:25 PM
  2. Lock Actuator?
    By WOTFTW in forum General Tech Discussion
    Last Post: 01-14-2011, 01:12 PM
  3. Temperature Actuator
    By s7falcon in forum Shops and Community Heroes
    Last Post: 09-04-2009, 11:36 AM
  4. Throttle Actuator
    By chrisothoulos in forum General Tech Discussion
    Last Post: 05-22-2009, 03:56 PM
