Thread: Hey guys
Results 1 to 16 of 16
  1. #1 Hey guys
    I'm thinking about putting in a supercharger in my 97 grand prix Gt but everyone is says I'm nuts if I do that. Is it really a bad idea to do that? I have couple of little problems well for one like everytime I hit a nice size bump on the road or I peal out on days when the road is wet like my abs and my tire pressure light comes on and I can't seem to figure out why? I am thinking maybe one the senors is going. I feel dumb but I notice when my abs light is on my traction control doesn't kick in. Traction control could of save me from spinning out on the highway when it snowed pretty badly here. JjAlso another issue is that when I'm driving on the highway I hear a noise like something is loose as hell but it only makes noise when I go faster then 75mph. The noise is coming from what I can hear the right rear wheel area it might be the brake or the exhaust system in that area. So let me know what you guys think alright.
  2. #2 Re: Hey guys
    May 2011
    ohio
    welcome
    if you want to put a supercharger on you car you might want to read this link it will till you everything about putting it on
    http://www.grandprixforums.net/top-s...info-7763.html
    also read this if your wanting to mod
    http://www.grandprixforums.net/safel...car-17482.html
    Bunnell, FL
    Abs and tsc are a linked system. Like the 3rd barks light and cruise control
    Android Fire
    I'm a Sex Offender
  4. #4 Re: Hey guys
    Alright thanks guys, i know this is a dumb question and this is my first car also but how do u perform a good maintenance on your car besides checking and replacing the spark plugs and changing the old and oil filter and rotating the tires
  5. #5 Re: Hey guys
    Start searching, reading until your eyes bleed and learn all you can. At this point I think it would be a big mistake for you to supercharge your motor. You would be better off learning and gaining the understanding about motors/cars etc before you jump into such a project.
  6. #6 Re: Hey guys
    GTX Level Member f3racer's Avatar
    dongducheon, south korea
    i agree with billboost. if you dont have the knowledge of basic maintenance then you dont need to tackle any modifications at all. if you have that extreme desire for more power then find someone who can do the work for you and maybe teach you some things along the way.
    SSG US Army Military Police
    2006 Grand Prix GXP
    http://gmls4.com
  7. #7 Re: Hey guys
    well I do read understand motors i read about it everyday, and so today i found out that when i looked when i kept on hearing noise when I go over 75mph I now know what that noise is its the one of the exhaust brackets had broke at the weilding point and it just kept on hitting my ebrake cable thats maybe why the abs light always came on, And when i bought the car the it already had aftermarket flowmaster exhaust system the guy didnt take good enough care of the car its like never washed the car there is some super some grey spots that u cant really see and there is rust starting to form in little areas im like ugh i ****ing hate rust on my paint, and i gotta have the tint and my window redone and gotta get a new side mirror cause the motor on the mirror won't let it go up or down it just can go side to side and i have to look on ebay for a red side mirror.the guy was subbing to hard.
  8. #8 Re: Hey guys
    ik a guy who can show me how to do it but he's not much into engines anymore all he cares about is audio stuff
  9. #9 Re: Hey guys
    We can also show you how to do stuff.
    The hanger on the ebrake cable has nothing to do with the abs. The ABS is controlled via a computer and uses the sensors in all four wheel hubs. My first thought when you mentioned it was that one hub or the wiring leading to the hub was bad.
  10. #10 Re: Hey guys
    Are you talking about the abs sensor or the wiring leading to the sensor sorry i am dumb just so i have a better understanding of what u mean .
  11. #11 Re: Hey guys
    where in the wheel hub is the abs sensor?
  12. #12 Re: Hey guys
    I talked about it possibly being either one of the sensors or one of the wiring leads. The ABS sensor is integral to the wheel hub and can't be replaced seperately. Depending on your year, a handheld scanner may or may not be able to read the wheel sensor codes. I think 2000 was the first year they could be read easily.
  13. #13 Re: Hey guys
    One way to check the earlier cars for a wheel sensor and this isn't an exact science..but use an ohm meter between the two leads and look for the one that is much different than the others. The wiring isn't quite as easy. might be a dirty connection, might be a pulled wire etc..
  14. #14 Re: Hey guys
    Yeah I use my step uncles on my car when the abs light was on and it didnt find anything at all and i still gotta fix the ****ing cable for the srs air bag in the passenger air bag.
  15. #15 Re: Hey guys
    On your 97, you need a serious scanner, say a Tech2, Snap On MT2500 etc. Those can view each wheel speed and all the body codes. I have HPT and in my 2000 the PCM stores either a U or B code for the sensor that it sees as bad. I don't think that is built into your year.
  16. #16 Re: Hey guys
    I found the wire the cause the light to come on while I was doing the rear brakes the right ones and I saw a cable and it was the cable that caused the light to go on and the cable didn't have any kind of protection over it and it was broken at the connection part.
  1. Hi guys
    By mygt in forum Introductions/Noob Questions
    Last Post: 06-22-2010, 10:52 PM
  2. what do u guys think i should do?
    By chitownwhitestrip in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2010, 10:38 AM
  3. Hi Guys
    By 08GrandGXP in forum Introductions/Noob Questions
    Last Post: 03-29-2009, 11:08 AM
  4. attn: guys who are car salesman or guys who know them
    By shaferz in forum Off Topic Discussion
    Last Post: 03-25-2008, 05:05 PM
