Thread: 2002 gtp
Results 1 to 15 of 15
  1. #1 2002 gtp
    Dekalb, IL
    Hello every one,
    I have a 2002 GTP with a Gen 5 swap with 3.1" pulley, NIC cam, Full size ZZP Inter-cooler, K&N Intake, MSD Coils and Wires, NGK plugs, SLP Headers, Borla cat-back. I Need to add a N*TB and I will be set. ZZP dyno said 301WHP and 391 torque with zero KR
    Ryan
  2. #2 Re: 2002 gtp
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    welcome to the site!
    but your using a 3.0 with those mods? are you scanning for knock?
    pics of car?
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  3. #3 Re: 2002 gtp
    Dekalb, IL
    Yea I have no knock and I went that low after asking my mechanic. I was at 3.4 before. Ad I will have pics in a month. Im in kuwait now so my car is sitting in storage waiting for me to come home!
  4. #4 Re: 2002 gtp
    Welcome
    You know he mean KR as in "knock" right? Like retarding the timing.
    Not doubting your knowledge or your mechanics knowledge, but how well does he know what he is talking about?
    Jumping from a 3.4 to a 3.0 is HUGE, and normally means more mods than what you have to run safely.
  5. #5 Re: 2002 gtp
    Dekalb, IL
    My mechanic knows his stuff. Also the place I buy parts said it will be fine to use just need a IC to go lower with some internals. My car is running perfect and have been running it for over a year now.
  6. #6 Re: 2002 gtp
    Modding the bottom end is not needed to go lower.
    You could do a cam or IC and drop more, or stay the same size and run more timing to get the most out of it.
    A cuztom tune, a scangauge and Wideband would be needed.
  7. #7 Re: 2002 gtp
    Dekalb, IL
    I have a custom tune for it. Since I blew my IAC within the first 2 weeks of putting it on. I put the headers on at the same time. But learned the hard way with it and now its running perfect. trying to get a ported SC and TB now
  8. #8 Re: 2002 gtp
    I know you have a custom tune now, but I was saying if you went farther a tune with either DHP or HPT buy a tuner would be key.
    Also, ported blowers are great, but porting the throttle body will require a custom maf tune to make it read right so the car runs right. It may be best not to do that one because I dont think you are outflowing the stock TB yet.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    The key to running that pulley on those mods are the msd coils and ngk spark plugs.....
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
    For all your 3800 needs:
  10. #10 Re: 2002 gtp
    Dekalb, IL
    Ah... thanks for the TB advice. Never really crossed my mind. And copgtp that's what I am using right now.
    Orange County, NY
    Sweet! You should b good brah.
  12. #12 Re: 2002 gtp
    Dekalb, IL
    haha i put MSN in my intro not MSD... MY BAD!!!!!
  13. #13 Re: 2002 gtp
    GTX Level Member crbquist's Avatar
    Massachusetts
    How in the world do you have no KR running a 3" pulley with just headers and an intake. You are seriously scanning with some sort of scan tool and have NONE?
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  14. #14 Re: 2002 gtp
    Dekalb, IL
    yea no KR. I scan pretty often. Got a custom tune and it runs perfect
  15. #15 Re: 2002 gtp
    How are you scanning and with what?
    I could possibly see a 3.3" with a richer AFR but a 3.0"? You need bigger injectors for that cuz.
    Otherwise, welcome.
  1. 2002 GT in OH
    By bigbair45 in forum Introductions/Noob Questions
    Last Post: 03-05-2010, 11:41 AM
  2. 2002 GTP vs. 2002 audi S4
    By JbrownGTP in forum Track Sessions and Kills
    Last Post: 07-07-2009, 11:50 PM
  3. 2002 gt
    By zbee in forum Introductions/Noob Questions
    Last Post: 05-04-2009, 07:04 AM
  4. 2002 gt
    By Snake in forum Introductions/Noob Questions
    Last Post: 05-01-2009, 08:38 PM
