Thread: 97 grand prix gt starting problem
Results 1 to 10 of 10
  1. #1 97 grand prix gt starting problem
    Jan 2012
    United States
    i own a 97 grand prix gt coupe 3.8 series 2 i just changed the starter on and new spark plugs and new battery but the car wont start still wont even crank. checked the starter its good and when i put the red battery cable it fried the bolt and melted the part of the battery where you skrew in the bolt. need help
  2. #2 Re: 97 grand prix gt starting problem
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    did you check all the grounds? Was there any symptoms before it had this problem?
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: 97 grand prix gt starting problem
    Houston
    Quote Originally Posted by Besimm;723891[COLOR=#3e3e3e
    when i put the red battery cable it fried the bolt and melted the part of the battery where you skrew in the bolt.[/COLOR]
    Need some clarity on this....what exactly and how exactly did this happen?
  4. #4 Re: 97 grand prix gt starting problem
    Jan 2012
    United States
    ill check all the ground wires today and the terminal where you connect the battery and the wire melted when i connected it the car automatically tried to start without the key in the ignition
  5. #5 Re: 97 grand prix gt starting problem
    Jul 2011
    Michigan
    do you have remote start? This happened to me when I was working on my brothers car. I had to suffocate the motor. After I stalled it though, everything works right.
  6. #6 Re: 97 grand prix gt starting problem
    Jan 2012
    United States
    no it doesnt have remote start
  7. #7 Re: 97 grand prix gt starting problem
    Jul 2011
    Michigan
    could you hear the starter gear sticking (like turning the key when your car is already started). Im betting the starter is wired wrong somehow.
  8. #8 Re: 97 grand prix gt starting problem
    Jan 2012
    United States
    the starter is good and im thinking its the wiring that went bad somewhere just dont know where if anyone knows the help would be greatt!!!
  9. #9 Re: 97 grand prix gt starting problem
    If you can take a pic of the wiring going to the starter maybe you got a wire on wrong or touching.
  10. #10 Re: 97 grand prix gt starting problem
    It sounds like the postive lead is touching the soleniod wire or you hooked it to the wrong post.
  1. 04 grand prix starting issue
    By 04grand in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-29-2011, 04:29 PM
  2. 98 grand prix starting problem
    By foosyerdaddy in forum General Tech Discussion
    Last Post: 08-07-2011, 06:43 PM
  3. Problem starting my 2000 Grand Prix
    By HNorm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-05-2011, 05:38 PM
  4. 01 grand prix starting problems
    By jerrynorman in forum General Tech Discussion
    Last Post: 04-23-2011, 10:08 AM
  5. 92 Grand Prix SE starting problem
    By Jhowie in forum General Tech Discussion
    Last Post: 03-17-2011, 09:24 PM
