Thread: vibration....Lowering springs?
Results 1 to 13 of 13
  1. #1 vibration....Lowering springs?
    SE Level Member BillGTX's Avatar
    Jul 2011
    Salem NH
    Hello to all!
    New to forum and looking forward to reading and adding to the posts as I can. Nice to see passion for the Pontiac Nation! Have enjoyed reading posts for a little while and decided to join today.
    Was wondering if someone could direct me to taking care of a problem I am having with vibration felt when under load anitially when taking off from stop, also when "getting on" the throttle you can feel it consistently.
    I just replaced both drive shafts and did help, but problem is still there.
    Everything is reel tight and there is no problem w/ wheels. I did have SLP lowering springs I installed about 4 yrs ago (1"drop). One of the springs broke (rotted), so I replaced w/ B&G about a month ago (1.25" drop.
    Thats when the vibration started. I've read in the forum about an option provided by "Vinnie", could someone get me in contact with him to see if he has a fix for me. Thanks again, BillGTX
  2. #2 Re: vibration....Lowering springs?
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    I would think the uneven drop itself would cause this vibration your car is not balanced at all. But i know nothing about lowering
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  3. #3 Re: vibration....Lowering springs?
    Jul 2011
    Salem NH
    Sorry, I did't clarify. I replaced all the springs with B&G (1.25" drop)
    Thanks!
  4. #4 Re: vibration....Lowering springs?
    Jul 2010
    Michigan
    Ahh ok then im sure someone thats does the lowering stuff in will be able to help you if it has anything to do with it. Maybe Bio can help you he does alot of suspension stuffs
    2005 GTP Grey
  5. #5 Re: vibration....Lowering springs?
    Jun 2011
    Detroit, MI
    I think these would help:
    ZZ Performance
    It has these benifits:
    Better oil pickup during drag racing
    Removes vibration caused from lowering the car
    Better axle alignment for less HP loss through the shafts
    Increased weight on the front tires for better launching
    Added clearance to sway bar for header and downpipe installs
    Hope I helped!
    iLoveSpade
  6. #6 Re: vibration....Lowering springs?
    Your axle angle is messed up.
    Get engine and tranny mount spacers.
  7. #7 Re: vibration....Lowering springs?
    Jul 2011
    Salem NH
    I've heard of two sources, zz performance and a guy who I believe is a member on this forum (Vinnie?) Please direct me
    Thanks, BillGTX
  8. #8 Re: vibration....Lowering springs?
    MA
    bill, were you by any chance outside of advanced autoparts in salem nh the other day? with your beautiful red GTX? i think i may have saw you as i ran into CVS.
    SMGPFC Member #9
  9. #9 Re: vibration....Lowering springs?
    MA
    SMGPFC Member #9
  10. #10 Re: vibration....Lowering springs?
    Jul 2011
    Salem NH
    Yah, that was me. Battery had died, so was in the process of installing an Optima red top. Sorry I missed ya. Thanks for the link.
  11. #11 Re: vibration....Lowering springs?
    MA
    small world eh
    SMGPFC Member #9
  12. #12 Re: vibration....Lowering springs?
    Charles City, IA
    Quote Originally Posted by SilvaMan61 View Post
    small world eh
    Canada's big tho eh?
    SMGPFC Two Nipple General
  13. #13 Re: vibration....Lowering springs?
    Jul 2011
    Salem NH
    Certainly is. I'll be looking for your Silver beauty
  1. Terrible acceleration vibration with lowering springs
    By real diehl in forum Brakes/Suspension/Chassis
    Last Post: 08-30-2010, 09:33 PM
  2. lowering springs
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 03-22-2009, 02:16 AM
