Thread: hi im new too forums and looking for help
Results 1 to 9 of 9
  1. #1 hi im new too forums and looking for help
    Apr 2011
    magnolia
    I currently drive a 2000 gp gt coupe. My transmission shifts perfectly until my trans warms up. Any ideas on problem?
  2. #2 Re: hi im new too forums and looking for help
    Donating Users
    South Deerfield, MA
    How does it shift after it warms up?
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: hi im new too forums and looking for help
    Apr 2011
    magnolia
    Every gear hard shift and if I give it gas it will shake entire car before it shifts.(shakes only at higher rpm) I checked my trans fluid color its good. Does not smell burnt. And the level is perfect
  4. #4 Re: hi im new too forums and looking for help
    Donating Users
    South Deerfield, MA
    Soungs like the problem my last GP had. Turned out to be a solenoid in the transmission. When the trans takes longer to shift than it expects it will shift at max pressure until the car is shut off. Next time you start it, you will get normal shifts until a long shift is detected and then the problem is back. If I remember right, the code was P1811.
  5. #5 Re: hi im new too forums and looking for help
    Donating Users
    South Deerfield, MA
    This will help you:
    Harsh Shift, P1811
  6. #6 Re: hi im new too forums and looking for help
    Apr 2011
    magnolia
    Okay awesome. If that is the case.. how much does it cost or how hard is it too replace the solenoid?
  7. #7 Re: hi im new too forums and looking for help
    Donating Users
    South Deerfield, MA
    I had a trans shop do it and had it rebuilt. I was planning on keeping that car for a while, but got rear ended and totalled it. The solenoid isn't that expensive, but they said you had to pull the trans to replace it so the labor was high. I think I've seen people on here say it can be done in the car if you know what you're doing.
  1. New to the forums... not to the car.
    By pontiacfan22 in forum Introductions/Noob Questions
    Last Post: 07-06-2010, 07:44 PM
  2. New to GP forums. 97 GT first car.
    By EJOUIE in forum Introductions/Noob Questions
    Last Post: 03-15-2010, 10:43 PM
  3. New to GP Forums
    By 08GPKID in forum Introductions/Noob Questions
    Last Post: 03-11-2010, 09:31 AM
  4. New to GTP forums
    By Big Vic in forum Introductions/Noob Questions
    Last Post: 11-26-2008, 01:02 PM
  5. new to the gp forums
    By sparkinjealousy in forum Introductions/Noob Questions
    Last Post: 06-10-2008, 11:04 PM
