Thread: Hello from PA
Results 1 to 18 of 18
  1. #1 Hello from PA
    PA
    Hi my name is Jim, I recently acquired a 1997 Gran Prix GT 3.8L. I hope to use this forum for some very good advice.
    Okay now here is my issue, I just replaced the water pump, thermostat, all hoses, serpentine belt and removed the coolant resevoir to completly clean it out. I don't seem to have any leaks, but now my heater doesn't get hot when the car comes up to temp.
    thanks i advance for any help,
    Jim
  2. #2 Re: Hello from PA
    Jul 2008
    Tampa, FL
    welcome jim, make sure and post your questions in the appropriate sections next time, you'll get stuff answered lots quicker. the thermostat could be stuck open, but that's the only suggestion i've got for ya. try a new one? they're only 5 bucks
  3. #3 Re: Hello from PA
    MO
    welcome
    Did you flush your heater core? That could be the culprit considering all the other parts you've replaced.
    <brandonl2000> LMAO D!!
  4. #4 Re: Hello from PA
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    where in pa?
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  5. #5 Re: Hello from PA
    Pennsylvania
    You could have air in your cooling system, search for the proper bleeding procedure.
    The guys on here can be really helpful, if not sarcastic or smart-assed sometimes
    It's for sure one of the better GP forums on the net, I read comments about how great it is here from people who frequent other forums all the time.
    Im also from PA, where are you located?
  6. #6 Re: Hello from PA
    Mercer, Pa
    I'm in PA as well!
    You have air in your system, there is a bleeder on top of your upper hose on the intake manifold, you can crack that open. if you already drove the car, check the level it will be low. Add some more and run it with the cap off. Let it get up to temperature, you will have to add more coolant several times.
  7. #7 Re: Hello from PA
    Pennsylvania
    sseil, what part of PA are you from? I've already talked to zildjian, he's real close to me, and he's old news
  8. #8 Re: Hello from PA
    SWPA
    I'm also in PA.
    I'm with the other guys though. You either have air in the system and/or not enough coolant. If there isn't enough coolant it will bypass the heater core.
  9. #9 Re: Hello from PA
    Indiana
    Welcome!
    This forum is very helpful, you'll learn a lot!
  10. #10 Re: Hello from PA
    Mercer, Pa
    Quote Originally Posted by FriboRage View Post
    Mercer (western pa north of pittsburgh)
  11. #11 Re: Hello from PA
    looks fast.... its slow:) beckys2000gt's Avatar
    Nov 2009
    stoystown, pa
    welcome to the forum...... pa here too
  12. #12 Re: Hello from PA
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Welcome, Just outside of PA here in Maryland
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  13. #13 Re: Hello from PA
    Pennsylvania
    Welcome, PA here, too.
  14. #14 Re: Hello from PA
    Welcome to the site!
  15. #15 Re: Hello from PA
    MA
    welcome
    SMGPFC Member #9
  16. #16 Re: Hello from PA
    PA
    I'm from Easton PA. WOW I can't believe all the responses I got. Alot of good info Thanks, just to let everyone know it was air in the line. Car is running great and heater is working fine. ( good thing because it is starting to get cold again. )
    Thanks to everyone again,
    Jim
  17. #17 Re: Hello from PA
    im in lancaster and welcome!
  18. #18 Re: Hello from PA
    SWPA
    Quote Originally Posted by jharry83 View Post
    Jim
    Which Easton? There is one in north centralish PA and then one on the Jersey border. I've got friends in the one out next to jersey that have a shop.
