Thread: New guy, plus engine change
Results 1 to 9 of 9
  1. #1 New guy, plus engine change
    Charlotte NC
    Hey guys, My name is Josh, im 16, and I just got my first car which is a 98 Grand Prix GT. Im here to learn all i can and be that guy that ask's the retarded questions that everyone should already know. I just recently bought a GTP engine to replace my factory GT and i was wondering if theres anything i should know about before swapping the two because its always easier to add on before its in the car, and also if theres anything i should keep up with on a supercharger besides oil, thanks!
    16 years with a 98 3.8 Supercharged Grand Prix
  2. #2 Re: New guy, plus engine change
    If you're not swapping the transmissions as well you're going to need a tune.
  3. #3 Re: New guy, plus engine change
    Charlotte NC
    ok, thanks. no im not switching the transmission so ill look into that.
  4. #4 Re: New guy, plus engine change
    Texas
    I would have kept the GT engine and done a top swap myself. Good luck with the build. What are your plans with it?
    85 Corvette
    01 TA
    03 Z06
  5. #5 Re: New guy, plus engine change
    I live here. TLSheff's Avatar
    http://www.grandprixforums.net/safel...car-17482.html
    ^^^^ READ IT ^^^^ *will save alot of questions...
    A thought before you put the engine in, spend the $200 or so and replace the LIM gaskets while its out. The factory ones are plastic and Dexcool coolant does wonderful things to them and you get internal leaks and then blown headgaskets or some kind of engine problem. Aluminum Fel-Pro gaskets are the way to go, follow the link for all the stuff you need to do and more reading material. http://www.grandprixforums.net/video...utes-3112.html
    & for some extra info -
    http://www.grandprixforums.net/lim-g...ign-39522.html
    I would also change out the engine oil, supercharger oil, if its got any play in the supercharger change the coupler (How to replace an M90 snout coupler without removing the entire blower) New plugs, wires and throw in an air intake http://www.grandprixforums.net/fwi.php
    Theres numerous other things I could come up with to start but Id knock out the basics to make sure its ready for driving before modding. If these have been done skip to whatever your pocketbook can handle
  6. #6 Re: New guy, plus engine change
    Charlotte NC
    well the reason im changing is because i have a knocking in the GT engine. I was wondering if its worth getting the GTP engine for $350 and free installation?
  7. #7 Re: New guy, plus engine change
    brookfield connecicut
    get some books and do alot of reading to learn as much as you can,
  8. #8 Re: New guy, plus engine change
    Michigan
    changing from standard to a supercharger would involve having to change the computer its actually alot more work than it seems. goodluck
  9. #9 Re: New guy, plus engine change
    Quote Originally Posted by Cspservices53 View Post
    ^ Obviously never done a top swap, Lower block is the same between them, just compression difference, sensors change, need to reprogram computer to compensate, not too much work, just alot of prepwork
  1. Change oil at what %?
    By shawnz90 in forum General Tech Discussion
    Last Post: 07-25-2011, 09:04 AM
  2. What do I need to change?
    By PurpleGuy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2011, 10:58 PM
  3. Engine Revving after filter change
    By mikeh in forum General Tech Discussion
    Last Post: 01-18-2010, 12:29 AM
  4. What should I change?
    By atruebudfan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2009, 02:13 PM
  5. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
