Thread: I need help
Results 1 to 8 of 8
  1. #1 I need help
    SE Level Member 2004mikegtp's Avatar
    PARMA
    i have a 2004 Pontiac grand prix gtp comp g that i want to hook up fuel air ratio gauge to? i hooked it to a white wire on my 02 sensor but it keeps reading lean and doesnt rotate around when i know its suppose to. its a narrowband i am considering buying a wideband but dont want to if its not going to work? any suggestions of what im doing wrong??
  2. #2 Re: I need help
    Factory o2's are Narrowband...so you just got a gauge to read your narrowband...which would just be reading the factory o2 readings?
    Should have just bought a Wideband in the first place since narrowband/factory isn't much fun.
  3. #3 Re: I need help
    PARMA
    I got the gauge for free so thats no big deal. Its like its hooked to white wire.. but doesnt read anything except lean? so if i buy a wideband it will work right reading the correct numbers without buying another 02 sensor?
  4. #4 Re: I need help
    Minnesota
    Im pretty sure you need a wideband o2
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  5. #5 Re: I need help
    Hagerstown,Md
    Wideband has its on special 02 sensor
  6. #6 Re: I need help
    PARMA
    you mean i need a narrowband 02?
  7. #7 Re: I need help
    Donating Users gtp239's Avatar
    ft myers fl
    stock o2 is narrow band
    1998 gtp fwi, sd headers, overkill,3.4, poly mounts,p&psc
  8. #8 Re: I need help
    PARMA
    why does it read lean the hole time and doesnt move off the red? what color wire does it need to be hooked to off an 02 sensor
