Thread: What should my first mod be ?
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
97GTPxWhiTe What should my first mod be ? 11-12-2010, 03:39 PM
MizzBecca Re: What should my first mod... 11-12-2010, 03:49 PM
CTKGP09 Re: What should my first mod... 11-12-2010, 03:58 PM
biggt Re: What should my first mod... 11-12-2010, 05:18 PM
TLSheff Re: What should my first mod... 11-12-2010, 05:21 PM
MizzBecca Re: What should my first mod... 11-12-2010, 06:23 PM
OrangeL67 Re: What should my first mod... 11-12-2010, 06:32 PM
matt5112 Re: What should my first mod... 11-12-2010, 09:28 PM
cliffdawg Re: What should my first mod... 11-12-2010, 10:03 PM
matt5112 Re: What should my first mod... 11-12-2010, 10:04 PM
ZR1Vette09 Re: What should my first mod... 11-12-2010, 10:29 PM
97GTPxWhiTe Re: What should my first mod... 11-13-2010, 10:29 AM
97GTPxWhiTe Re: What should my first mod... 11-13-2010, 10:37 AM
97GTPxWhiTe Re: What should my first mod... 11-13-2010, 10:42 AM
97GTPxWhiTe Re: What should my first mod... 11-13-2010, 10:44 AM
Mitchstrp Re: What should my first mod... 11-13-2010, 10:54 AM
blueguy Re: What should my first mod... 11-13-2010, 11:03 AM
Mitchstrp Re: What should my first mod... 11-13-2010, 10:55 AM
blueguy Re: What should my first mod... 11-13-2010, 11:04 AM
97GTPxWhiTe Re: What should my first mod... 11-13-2010, 11:10 AM
97GTPxWhiTe Re: What should my first mod... 11-13-2010, 11:14 AM
ZR1Vette09 Re: What should my first mod... 11-13-2010, 06:48 PM
blueguy Re: What should my first mod... 11-13-2010, 11:16 AM
codyAK Re: What should my first mod... 11-13-2010, 12:49 PM
matt5112 Re: What should my first mod... 11-13-2010, 12:38 PM
Jakescoots Re: What should my first mod... 11-13-2010, 05:08 PM
MizzBecca Re: What should my first mod... 11-13-2010, 08:20 PM
blueguy Re: What should my first mod... 11-13-2010, 10:15 PM
cliffdawg Re: What should my first mod... 11-13-2010, 10:29 PM
MizzBecca Re: What should my first mod... 11-13-2010, 10:41 PM
matt5112 Re: What should my first mod... 11-13-2010, 10:53 PM
SeanGTP Re: What should my first mod... 11-13-2010, 10:57 PM
MizzBecca Re: What should my first mod... 11-13-2010, 11:07 PM
Jakescoots Re: What should my first mod... 11-13-2010, 11:45 PM
MizzBecca Re: What should my first mod... 11-13-2010, 11:55 PM
TLSheff Re: What should my first mod... 11-15-2010, 10:49 AM
SeanGTP Re: What should my first mod... 11-15-2010, 01:17 PM
blueguy Re: What should my first mod... 11-15-2010, 03:53 PM
gtpinsc Re: What should my first mod... 11-15-2010, 05:33 PM
biggt Re: What should my first mod... 11-16-2010, 01:11 AM
  1. #1 What should my first mod be ?
    Nov 2010
    Lake ronkonkoma
    ive had my GTP since april and im looking to put some work into it, looking into a pully and other stuff but everythings just too much, anyone hve any ideas of what i should do first ?
  2. #2 Re: What should my first mod be ?
    Becca Boo MizzBecca's Avatar
    Michigan
    cold air intake.
    I drive a POS
  3. #3 Re: What should my first mod be ?
    Willoughby, Ohio
    agreed intake is the first mod, along with flipping your dogbone mounts since its free
    also read this
    http://www.grandprixforums.net/new-m...ads-36503.html
  4. #4 Re: What should my first mod be ?
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    intake!
    Quote Originally Posted by CTKGP09 View Post
    also read this
    what does fliping your dog bones give you?
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  5. #5 Re: What should my first mod be ?
    I live here. TLSheff's Avatar
    9000hp instantely
    j/k http://www.grandprixforums.net/dog-bone-flip-13286.html
    Quote Originally Posted by Abrasive View Post
    You basically turn this....
    Into this....
    I do it just as Scimmia described, by removing the torque strut (dogbone) from in between the part pictured above and the engine brackets just to get it completely out of the way. Then with the bracket still attached to the car, put the bolt back through the bushing and tighten down the nut completely. Then I take a flat screwdriver and pry the rubber bushing back just enough to spray some lubricant in behind it all the way around. A little WD-40 works good. Then I put a 15mm wrench on the bolt head and another on the nut that I just put back through the rubber bushing and begin pushing the two wrenches towards the engine. Turn them slowly to make sure you are not tearing the bushing and sometimes you have to work them back and forth a little bit to get the entire bushing to "flip" 90 degrees. Once finished, the bushing is now solid on the front and back which is where the engine puts the most force against them as it tries to move back and forth. Then just take the nut off and remove the bolt, reinstall your dogbones, and you're done.
  6. #6 Re: What should my first mod be ?
    Michigan
    Quote Originally Posted by tlsheff View Post
    no thats the performance ebay computer chip. Duhhhhhhhh.
    I drive a POS
  7. #7 Re: What should my first mod be ?
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    Buy a turbo and go pick on some vettes
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  8. #8 Re: What should my first mod be ?
    Guys...
    You're ALLLLLLLLLLLLLLLLL Wrong.
    You want a perf transmission.
    The end.
    If not, buy an intercooler then buy a transmission.
    Or buy a turbo kit after the transmission.
    But again, transmission.
    Last edited by matt5112; 11-12-2010 at 09:31 PM. Reason: Trannys, you know you want one.
  9. #9 Re: What should my first mod be ?
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    i agree with the trans but im buying my things little bit here and there so that way when i do my trans i already got the intercooler but everything can go on all at once
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  10. #10 Re: What should my first mod be ?
    but first mod speed daddy headers lol
    SMGPFC #77
  11. #11 Re: What should my first mod be ?
    If you dont want to do that then at LEAST do a U bend delete or get the speed daddy headers.
    $205 to your door.
    And no, a transmission and a full size intercooler are better things to spend your money on than any headers.
  12. #12 Re: What should my first mod be ?
    MO
    The read mod
    <brandonl2000> LMAO D!!
  13. #13 Re: What should my first mod be ?
    Nov 2010
    Lake ronkonkoma
    thanks, i already have a supercharger so i dnt need the turbo and ill def get the cold air intake and how much would a tranny be and wich one would i get ?
  14. #14 Re: What should my first mod be ?
    Nov 2010
    Lake ronkonkoma
    also i bought an intake for my car but theres a computer in the box your supposed to take out what should i do with that ?
  15. #15 Re: What should my first mod be ?
    Nov 2010
    Lake ronkonkoma
  16. #16 Re: What should my first mod be ?
    Nov 2010
    Lake ronkonkoma
  17. #17 Re: What should my first mod be ?
    GT Level Member Mitchstrp's Avatar
    Missouri
    Quote Originally Posted by 97GTPxWhiTe View Post
    no chip is a good chip, just a scam which people continue to buy into, change your thermostat 180* and start with exhaust, exhaust is whats going to help you out the most, personally id buy headers and get them installed itll make more difference then youll believe and you can get them for 200 bucks off ebay.
    1.8 RR's, Speed daddy headers, 180 stat, Open Cone, GBP tune, 3.5 pulley, and ported blower.
  18. #18 Re: What should my first mod be ?
    For my spill, guy. Click the link in my signature. If you would have done so like posted earlier in this thread...then you wouldn't be asking these ignant questions. I typed that long ass thread for a reason. To answer people's questions like yours. Now...CLICK THE LINK...AND SIT DOWN FOR 10 MINUTES...and read? Yes...read. Best thing you can do as of now.
    NO.
    NO. Chip = you taking your paycheck and lighting it on fire. These cars need tuned PCM's.
    Quote Originally Posted by Mitchstrp View Post
    Changing to a 180* T-Stat without any other mods or having the fans set for a lower turn on point will only net you worse MPG's than anything else.
  19. #19 Re: What should my first mod be ?
    Missouri
    Also if your going to order online then i would recomend using the vendor websites that specialize in our cars, 3800performance.com, zzperformance.com, pfyc.com ect.
  20. #20 Re: What should my first mod be ?
    Quote Originally Posted by mitchstrp View Post
    also if your going to order online then i would recommend using the vendor website 3800performance.com
    F i x e d
