Thread: Having Ignition Switch Troubles
Results 1 to 2 of 2
  1. #1 Having Ignition Switch Troubles
    Calahoo Alberta Canada
    Key switch will not release to off position when car is shut off and in park. Depressing the shift button on the automatic shifter sometimes causes and solenoid noise in the steering column. The key switch then releases to off position and I can remove the key. I'm guessing that the switch at the base of the shifter has something to do with this. Can you buy just the switch or do you have to replace the whole shift mechanism.
  2. #2 Re: Having Ignition Switch Troubles
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    three options:
    http://www.grandprixforums.net/ignition_bypass.php
    pull the shift lock solenoid
    replace ignition switch
    i would do one of the latter two.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  1. ignition switch help
    By redrivergar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2010, 09:13 PM
  2. ignition switch cylinder
    By mtz956 in forum General Tech Discussion
    Last Post: 08-29-2010, 02:21 AM
  3. ignition switch
    Last Post: 08-10-2010, 04:53 PM
  4. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
