Thread: Newbie From Harrisburg PA
Results 1 to 5 of 5
  1. #1 Newbie From Harrisburg PA
    Jun 2010
    Harrisburg PA
    Wanted to put up where I am from in hopes that someone else out there is close. Need help with car ATM, hard to turn left.
  2. #2 Re: Newbie From Harrisburg PA
    looks fast.... its slow:) beckys2000gt's Avatar
    Nov 2009
    stoystown, pa
    welcome to the forum, im in pa too, maybe 2,5 hours from harriesburg
  3. #3 Re: Newbie From Harrisburg PA
    Pennsylvania
    Just left? If you can turn right fine, I would think that it's not a power steering pump so... suspension? Something could be cracked, bent, torn or broken in the front suspension. Until someone else has a better suggestion (which the undoubtedly will), I'd say stick your head under there and compare the right and left sides carefully - see if there's a difference.
  4. #4 Re: Newbie From Harrisburg PA
    Willoughby, Ohio
    welcome to the forums, can you be more descriptive please? as i noises it makes? at a certain speed or sitting still? this will help us diagnose the problem
  5. #5 Re: Newbie From Harrisburg PA
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    Welcome, about 2 hours away. Good luck with the car. Sounds like something is bound up.
    Retired
    Turbo'd
  1. Oh no, not another newbie..
    By Jackd90 in forum Introductions/Noob Questions
    Last Post: 05-14-2009, 11:15 PM
  2. A newbie from PA...
    By BlownBigBlock in forum Introductions/Noob Questions
    Last Post: 04-23-2009, 03:25 PM
  3. Newbie
    By Conrad in forum Introductions/Noob Questions
    Last Post: 04-17-2009, 08:49 PM
  4. Newbie with a '97 GT
    By widebodyGT in forum Introductions/Noob Questions
    Last Post: 04-17-2009, 08:40 PM
  5. newbie in PA
    By BLEWGTP in forum Introductions/Noob Questions
    Last Post: 12-04-2008, 12:31 AM
