Thread: Front end noise
Results 1 to 2 of 2
  1. #1 Front end noise
    hubbards
    I have a 2003 grand-prix GT. For the past few mths I heard a rubbing noice, sounded like brakes. I replaced the rotors and noise still there. I then thought it was a wheel bearing, So I change the drivers side.
    The noice is still there. When I drive very slow I can hear a noise that sounds like the brakes might be draging. Whe I push the brake lightly the noise goes away( for the most part). I was told that it could be a axal or the other wheel bearing. I don't have the money to keep replacing parts that I don't need.
    Can anyone have a suggestion for me??? Thanks in advance..
  2. #2 Re: Front end noise
    Toronto, Canada
    is the noise a squeaking noise ?
    I hear that from my 01 GT , and then if you apply the brakes its silent .
    on my car the rotors are old so I suspect they maybe a bit uneven ,
    you may want to check that the calipers can move freely and dont get stuck at all .. check the back calibers too ..
  1. Clunking noise in front end 04 gtp!!!!
    By justin98 in forum General Tech Discussion
    Last Post: 11-08-2011, 03:19 PM
  2. Right-Front Grinding Noise
    By cowmilker08 in forum General Tech Discussion
    Last Post: 06-07-2010, 01:36 PM
  3. front end noise, hub?
    By hourang in forum Brakes/Suspension/Chassis
    Last Post: 02-01-2010, 11:17 AM
  4. thumping noise comming from front end.
    By need2know29340 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-29-2009, 11:06 PM
  5. Roar noise from front end
    By markh in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:37 AM
