Thread: ABS and traction off lights are on- 98 Grand Prix GT
Results 1 to 6 of 6
  1. #1 ABS and traction off lights are on- 98 Grand Prix GT
    New Brunswick
    Hey, I'm hoping someone can help me figure out what's going on with my car. The ABS and Trac off lights are on. They are not on all the time, but often. I'm hearing a strange noise coming from the back when I am driving slow (when I first go into drive after backing out of my driveway). I am also noticing the brakes act funny when I have to use them in town. It's like they are sticking. I looked this issue up on Google and it pointed to the ABS module. I can get one for about $30 from a junkyard but I'm wondering if that really is the problem. Has anyone else had this issue, and if so how did you fix it? Any info would be greatly appreciated!
    Misty
  2. #2 Re: ABS and traction off lights are on- 98 Grand Prix GT
    Jul 2008
    sumter,south carolina
    could be alot of things, wheel speed sensor will cause it the lights to come on... but usually doesnt affect braking.. if they sticking it very well could be the module.
    02 GTP with mods 05 GP for DD
  3. #3 Re: ABS and traction off lights are on- 98 Grand Prix GT
    New Brunswick
    Thanks! I have a couple days off coming up so I think I'll try changing the module. See if that helps, if not I'll have to keep investigating I guess.
  4. #4 Re: ABS and traction off lights are on- 98 Grand Prix GT
    Jul 2008
    check brake fluid first
  5. #5 Re: ABS and traction off lights are on- 98 Grand Prix GT
    Windsor (ON) Canada
    I dont have any experience with the ABS module, but my ABS light came on and off, ABS would start to kick in (esp, taking 90* turns real slow) then the light was on all the time, basically it was my right front Hub assembly breaking down.
    This is a very common issue, you can find many threads (mostly helpful) on here using the search option. But its most likely either Module, or Hub assesmly
  6. #6 Re: ABS and traction off lights are on- 98 Grand Prix GT
    New Brunswick
    It ended up being both front wheel bearings.
  1. abs & traction lights
    By uNda6gT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 03:06 PM
  2. 04 grand prix traction control/ABS
    By mrmorris in forum Introductions/Noob Questions
    Last Post: 11-14-2009, 10:17 AM
  3. ABS/Traction Lights On
    By Strype in forum General Tech Discussion
    Last Post: 10-01-2009, 07:50 PM
  4. 2004 Grand Prix GTP ABS and Traction Control
    By jrjess in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2009, 06:50 PM
  5. 2000 grand prix traction control problem
    By marckub203 in forum Introductions/Noob Questions
    Last Post: 08-19-2009, 10:02 PM
