Thread: newb with a top swapped cammed GT
Results 1 to 15 of 15
  1. #1 newb with a top swapped cammed GT
    SE Level Member Mater's Avatar
    Feb 2010
    my house
    been lurking for a wile finaly decided to post. i have a 2001 GT. it was a base car with the the only options being the dual zone A/C, heated out side mirrors, and the 7 band graphic EQ CD player the car came from the factory with floor mats and onstar delete
    other then that i have seen SEs with more options
    got the car in october 26, 2007 exactly 7 years after it rolled off the assembly line in october 26, 2000. car stayed stock fro 3 months then 4th gear shaft went out in the 4T65-E at a 135,000 miles so i decided to rebuild it at school and since the engine was out well yeah
    best i have ran is a 12.99 @107 mph but i can not find the time slip so the only one i have proof of is the 13.543 @107 mph when i was running on junk tires and could not get it on the converter and had to leave off idle
    best dyno is 261 WHP thats with stock manifolds and a 3" DP no KR and a junk tune. still have the junk tune but now i have headers on the car
    here is a pic of it as it sits
    But why make it an SE?
    99 Grand Prix SE coupe:
    junk yard trans junk yard engine and junk yard turbo
    03 Silverado 2500HD ECSB: 6.0 4x4 01 Aurora:​ 4.0L vin number 2
  2. #2 Re: newb with a top swapped cammed GT
    Dec 2008
    Canada
    Now that you have headers you should tune for sure, and nice setup so far.
  3. #3 Re: newb with a top swapped cammed GT
    GT Level Member Bogers04SS's Avatar
    Feb 2010
    Mocksville, N.C.
    Welcome!
    04 Impala SS -- SOLD
    08 Prix GXP -- FWI, 3in DP, TR6IX plugs, Ported & polished throttle body, ported intake manifold, DiabLEW Tuned, wrapped crossover pipe, Cat delete, Factory res., Muffler delete, Poly motor mounts, shift kit, LED bulbs in just about every Da*n thing, ect..
  4. #4 Re: newb with a top swapped cammed GT
    Feb 2010
    my house
    thanks for the welcomes
  5. #5 Re: newb with a top swapped cammed GT
    Donating User Odi's Avatar
    Chicago South Suburbs
    Get rid of those ugly snowflake rims! Welcome
  6. #6 Re: newb with a top swapped cammed GT
    no, keep the snowflakes for the snowflake season and get some nice 17's for the summer.
  7. #7 Re: newb with a top swapped cammed GT
    GTP Level Member
    Nov 2008
    MA
    hey nice car man! if 12.99 is your best time then why not post that rather then the 13.5? **** i would, idc if i got proof or not.
    and they revved your **** to 6700 rpms on the dyno pull? godamn
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  8. #8 Re: newb with a top swapped cammed GT
    Feb 2010
    my house
    no i reved my car out to 6,700 on the dyno why would i let some one else have all the fun it shifts at 6,600 at WOT so i just went up a little higher to see where the cam peak was
    the reason for the 13.5 is if i am called out on it i like to back it up
  9. #9 Re: newb with a top swapped cammed GT
    Troy OH
    12.99's a good run man. i love how you have the gt sticker on the side, so misleading haha. where'd you go to school?
  10. #10 Re: newb with a top swapped cammed GT
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    wait a minute is this a gt or a gtp i kno it says (gt) but is it supercharged alota hp for a gt
  11. #11 Re: newb with a top swapped cammed GT
    Feb 2010
    my house
    Quote Originally Posted by Poil336 View Post
    Mt. Pleasant High school and i am going to Mid Michigan comunity college
    Quote Originally Posted by imdaman3 View Post
    the car was born as a N/A GT i put a S/C on top of the stock L36. think of it as a high compretion GTP engine
  12. #12 Re: newb with a top swapped cammed GT
    if you're going that high, what valve train mods do you have? Also, where does your HP peak occur? Not really sure its wise to shift that high with an m90
  13. #13 Re: newb with a top swapped cammed GT
    Feb 2010
    my house
    105 springs and a double roller rollmaster.
    the run was ended early becuase we still had the speed limiter set to 100 MPH and it aborted after it shifted into 3rd
    http://www.youtube.com/watch?v=5eUT8s0GRQQ
    EDIT: well damn i am blind it was at 6,398 i was looking at something else oops lol when i take the car out of it's sleep i am going to lower the shift points in the ZZP PCM
  14. #14 Re: newb with a top swapped cammed GT
    Feb 2010
    ohio
    never mind top swapped damn im blind lol
  15. #15 Re: newb with a top swapped cammed GT
    Oh... that lower speed makes sense.
    Only reason i ask is because i've heard theres risk of bending a pushrod at 6500.
  1. cammed 3.1 SE
    By ricardo23 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-12-2009, 05:36 PM
  2. Swapped Thermostats
    By dhall9 in forum General Tech Discussion
    Last Post: 07-19-2009, 03:56 PM
  3. L67 Swapped
    By 99LuminaLSC in forum Chevrolet Lumina
    Last Post: 12-15-2007, 08:57 AM
