Thread: 06 Grand prix remote start
Results 1 to 19 of 19
  1. #1 06 Grand prix remote start
    michigan
    Chats
    The remote start stopped working on my car. The remotes are fine, When I try to remote start it, I here the car click but no start. horn trips and the lights comes on. but still with no start. .The remote start feature is on in the DIC settings. both fobs works fine for lock trunk and all other accept the Remote start any ideas guys.
  2. #2 Re: 06 Grand prix remote start
    GTP Level Member tazyboy28's Avatar
    home town
    Chats
    maybe you let it sit and used the remote start twice in succesion but didn't drive the car. usually when u start it up twice and don't go anywhere it stops remote starting until u actually get in the car and turn the key to start it then it can be used again. but im pretty sure thats not the problem. just gotta give the most obvious answer.
    specs:2007 GP GT, wizair intake, ZZP headers, 3inch high flow cat downpipe. SLP power flo exhaust
  3. #3 Re: 06 Grand prix remote start
    May 2008
    Winnipeg, MB
    Chats
    has it just started doing this or has it been like this for awhile?
    2007 Pontiac Grand Prix
  4. #4 Re: 06 Grand prix remote start
    MO
    Chats
    508
    mine did that occasionally too, but once i had the reciever replaced it seemed to fix the problem. how's your range?
    <brandonl2000> LMAO D!!
  5. #5 Re: 06 Grand prix remote start
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    Chats
    Quote Originally Posted by kizy3647 View Post
    Probably a malfunction or issue with the anti-theft device. Good luck unless you are under warranty. Welcome to Genital Motors if you haven't already been welcomed! LOL! I love getting into a Cobalt with the KEY and it starts blowing the horn until you insert a properly programmed key.
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  6. #6 Re: 06 Grand prix remote start
    MO
    Chats
    508
    Quote Originally Posted by JoelW98GTP View Post
    see my above statement. could be an indicater that it's not quite recieving the full signal.
  7. #7 Re: 06 Grand prix remote start
    michigan
    Chats
    The Range is really low. It only works about 5- 10 feet away max.
  8. #8 Re: 06 Grand prix remote start
    MO
    Chats
    508
    i would have a dealer check it out then, i had the same issues and it was the reciever
  9. #9 Re: 06 Grand prix remote start
    St. Charles, MO
    Chats
    My remote start on my '06 GXP sets off the car alarm!
  10. #10 Re: 06 Grand prix remote start
    Nov 2009
    Portsmouth, OH
    Chats
    Quote Originally Posted by ZR1Vette09 View Post
    How much did that cost to have it fixed? If you had it fixed, did you do it or did GM do it?
  11. #11 Re: 06 Grand prix remote start
    St. Charles, MO
    Chats
    Quote Originally Posted by stlracing View Post
    Actually, one of my remotes will start the car remotely and the other remote sets off the alarm system when trying to remotely start it.
  12. #12 Re: 06 Grand prix remote start
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    Chats
    welcome man.......and joel, side note, its government motors, or gubba ment motors.lol!
  13. #13 Re: 06 Grand prix remote start
    Kansas City
    Chats
    bringing back a bit of an old thread, I'm having the same issue on my 07 GP. Just started (or lack of starting,,,,) last friday. Remote has good range I can lock/unlock and start from about 100 yards away. Didn't work when I got off of work on friday, same symptoms. Horn sounds, hear a click, hear the fuel pump kick in but no start. check engine light came on at the same time, had the code checked - P0411 - Secondary Air Injection system fault.
    Not sure if this would cause the issue with the remote start or not. I have not had a chance to start checking fuses/relays/ AIR system yet but plan on it this week.
    BTW,
    Hello to all at GP forums! been a member here for a bit but never really had a reason to post. Great forums!!
  14. #14 Re: 06 Grand prix remote start
    fort wayne
    Chats
    if they have been dropped a lot you will have a problem too. take it apart and see if the 3 connectors are still sodered.
  15. #15 Re: 06 Grand prix remote start
    Feb 2010
    Swartz Creek, MI
    Chats
    Quote Originally Posted by Forcheck View Post
    BTW,
    Your no remote start is directly related to your check engine light. my 06 GT did the same thing when the Check engine light came on for the boost bypass valve. replaced the part remote start works fine. It is a safety feature.
  16. #16 Re: 06 Grand prix remote start
    MO
    Chats
    508
    Quote Originally Posted by 05Sleeper View Post
    Another common problem... see my thread in the How-To section. sorry i never saw your post asking about price... my car is under warranty so it was free.
  17. #17 Re: 06 Grand prix remote start
    Mar 2013
    United States
    Chats
    My car is now having the same issue. I go to activate the remote start and the horn sounds but no start. Any suggestions before I go to the dwaler?
  18. #18 Re: 06 Grand prix remote start
    Dec 2012
    Where 4T65E's were born
    Chats
    22
    Well as long as you checked what the two guys said up there ^ Check the soldered connections in the fob, and make sure there are no codes
    Sold.
  19. #19 Re: 06 Grand prix remote start
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Chats
    Has anyone found resolution to this? My 07 GXP started doing this today. No CEL. If I push and hold the remote start and lock button at the same time it will start. Doing it the proper way sets off the alarm.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  1. Grand Prix won't start - 99 GT
    By socaljay66 in forum General Tech Discussion
    Last Post: 11-10-2009, 07:14 AM
  2. 97 Grand prix won't start... Need help... BAD...
    By 98gtxking in forum General Tech Discussion
    Last Post: 10-08-2009, 10:50 PM
  3. 97 Grand prix won't start... Need help... BAD...
    Last Post: 09-24-2009, 02:54 PM
  4. 96 grand prix 3.1 wont start cold
    By oldtruckluvr in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-17-2009, 08:51 AM
  5. 1999 Grand Prix sometimes won't start
    By sabram in forum Canada
    Last Post: 09-13-2009, 07:31 PM
