Thread: My First Car - 2000 GTP Coupe
Results 1 to 18 of 18
  1. #1 My First Car - 2000 GTP Coupe
    SE Level Member gorps's Avatar
    Ontario
    Hello Group,
    Dan from Ontario, Canada. Just bought my first car, a silver 2000 GTP Coupe. 328k and needed work done. Current issues are a leaky trunk, front seats not latching and OBD code C0035 (replaced front left wheel hub assembly and ABS light is still on) but can't complain that much for paying $700.
    I'm sure I'll have questions to ask in the future.
    Thanks,
    Dan
  2. #2 Re: My First Car - 2000 GTP Coupe
    Guam
  3. #3 Re: My First Car - 2000 GTP Coupe
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    welcome. wow thats alot of miles. i guess they can run 4ever
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  4. #4 Re: My First Car - 2000 GTP Coupe
    Norristown, PA
    Probably km.
  5. #5 Re: My First Car - 2000 GTP Coupe
    Nov 2008
    Waterloo, Iowa
    Yeah I was just going to say, I think Canadians use metric, not imperial. My car had a digital climate control that came out of Canada measuring the temp in Celsius, I had to pull it out to flip it to Fahrenheit.
  6. #6 Re: My First Car - 2000 GTP Coupe
    Charles City, IA
    Quote Originally Posted by rocafella2032 View Post
    Probably km.
    Thats still damn near 200,000 miles. Check the wiring harness going to the hub for opens.
    SMGPFC Two Nipple General
  7. #7 Re: My First Car - 2000 GTP Coupe
    Wow... I think we just had a blonde moment... I'm fairly certain the US is the only country that manufactures cars that still uses the imperial system as their standard... But still anything past 300K will only last if its been taken care of and you're going to continue to take care of it.
  8. #8 Re: My First Car - 2000 GTP Coupe
    Ontario
    Thanks for the input guys.
    Yes, I should have stated 328,000 KM. Sorry for the confusion.
    I hope to get 45,000km (2-3 years) out of it.
    I read the posts on ABS and resealing the spoiler. They were very informative.
    This site looks like it will be a great asset.
  9. #9 Re: My First Car - 2000 GTP Coupe
    Georgia
    Welcome to the forum.I have a 99 GTP with 191,000 miles on it I bought 2yrs. ago.It runs and looks good but has issues from time to time.This forum has been great for getting information for doing my repairs.Good luck with your car and be carefull these are powerfull cars that can build speed very quickly.
  10. #10 Re: My First Car - 2000 GTP Coupe
    Becca Boo MizzBecca's Avatar
    Michigan
    you came to the right place this place is full of guys that'll be able to answer every one of ur questions. take a look at the safely modding your 3800 thread if thats something you're interested in.
    I drive a POS
  11. #11 Re: My First Car - 2000 GTP Coupe
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by MiZzBeCcA View Post
    and quite frankly girls that can help just as much. =P
  12. #12 Re: My First Car - 2000 GTP Coupe
    Feb 2009
    philly philly
    welcome its good to know that the 3800 doesnt die if well tooken care of
  13. #13 Re: My First Car - 2000 GTP Coupe
    SE Level Member xopink89's Avatar
    Indiana
    Quote Originally Posted by SaW1833 View Post
    mine is doing the same thing right now. how did u fix it?
    pretty n pink
  14. #14 Re: My First Car - 2000 GTP Coupe
    Quote Originally Posted by xopink89 View Post
    Theres a switch on the back apparently.
    That or a different vac line to hook up to.
  15. #15 Re: My First Car - 2000 GTP Coupe
    Nov 2008
    Waterloo, Iowa
    Yeah. If I recall there is a switch on the back. You have to rip the dash apart and pull it out to get to it though.
  16. #16 Re: My First Car - 2000 GTP Coupe
    Uniontown
  17. #17 Re: My First Car - 2000 GTP Coupe
    SE Level Member 02PrixGT's Avatar
    Canada
    sup welcome fellow grand prix driving canadian
  18. #18 Re: My First Car - 2000 GTP Coupe
    Ontario Quebec Club Grand Prix • Index page
    If you ever have regional questions go there.
    Also the F/S section might be better than buying from the states.
  1. 2000 GTP coupe owner from Sarnia ON
    By smwalsh in forum Introductions/Noob Questions
    Last Post: 07-22-2009, 10:32 AM
  2. Hi Everyone 2000 gtp coupe
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2009, 08:41 AM
  3. new guy need help 2000 gtp coupe
    By mikedinthecity in forum Introductions/Noob Questions
    Last Post: 04-24-2009, 02:50 AM
  4. 2000 GTP Coupe Struts
    By cprher in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2009, 01:01 PM
