Thread: Interested in a GTP
Results 1 to 7 of 7
  1. #1 Interested in a GTP
    Central Valley
    Hi there, I am interested in purchasing a 97 coupe GTP for my lady and thought I'd wright you to see if there are any mechanical/electrical problems that I need to be aware of. I will most likely purchase a silver GTP with 137k miles this weekend for 2K, please let me know if this car is worth it.
  2. #2 Re: Interested in a GTP
    GXP Level Member
    Theworld
    IF there is no problems, sounds like a good deal.
    -Check the tranny stick for clutch material
    -Check the oil
    -Check for leaks
    -Make sure you drive it at 45 mph+ to make sure it goes in 4th gear.
    Electrical issues most of the time are blown fuses.. so if somethings not working, check the fuse first.
    If the a/c doesn't work, I'd offer $1500-1000 but it's still a good deal at 2k
  3. #3 Re: Interested in a GTP
    Jan 1970
    Maquoketa, Iowa
    The 97's were the first year of this design, so it is kind of the oddball as far as the gtp's go. There are a few things different on the 97's than 98-03's but as long as your not planning on modding it, it's not a very big deal.
    As far as checking the car out, like said above, these transmissions lose 4th gear sometimes, best way to check is to take it up a large hill that will put load on the car in 4th and if you feel a jerking, then its on its way out... Then check plugs and may want to ask if has the original fuel pump or when it was replaced. Also check the s/c by letting it run and listening for almost a popping sound around the snout. The next step would be to take just the s/c belt off and feel for play while turning the pulley back and forth, if there is, its most likely a worn coupler that is only $30 to replace, but if its a 140k stock s/c, you can find a used s/c for around $200.
  4. #4 Re: Interested in a GTP
    Central Valley
    Thank guys, I will do that when I see the car in person.
  5. #5 Re: Interested in a GTP
    SE Level Member Supercharged's Avatar
    Round Lake, IL
    They are great cars, you'll be very happy with it!
  6. #6 Re: Interested in a GTP
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    cant beat the performance 4 2k.
  7. #7 Re: Interested in a GTP
    SE Level Member zeww89's Avatar
    Alabama
    Quote Originally Posted by KawaFord View Post
    i dont think my gfs 01gtp has a 4th gear. was it still problematic in the 01s? the rpms never drop or raise when going from 3 to drive or drive to 3 and it never feels like it shifts out. but the rmps only get to about 3k at 70 down the road
  1. Would anybody be interested in 12'' FI Q?
    By robahr24 in forum Audio, Security & Visual Electronics
    Last Post: 07-21-2009, 08:32 PM
  2. Anyone Interested?
    By SyntheticShield in forum Forum Bugs/Suggestions
    Last Post: 09-04-2008, 08:19 AM
  3. Video idea if you're interested.
    By Abrasive in forum Forum Bugs/Suggestions
    Last Post: 02-20-2008, 11:28 PM
