Thread: Miss Lisa's GTP is dead
Results 1 to 4 of 4
  1. #1 Miss Lisa's GTP is dead
    Georgia
    Her 99 gtp has no fuel pressure. I have checked all fueses done the 85 relay bypass and connot hear the pump running.Is there an access hole in the trunk? Iwant to check for voltage at the pump.Whatis the best pump to buy.Our budget is tight.
  2. #2 Re: Miss Lisa's GTP is dead
    Jul 2008
    nj
    yh....pull up the carpet in the trunk and close to the rear seat there will be an access panel with a few bolts holding it down. easy to get too
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  3. #3 Re: Miss Lisa's GTP is dead
    Donating Users mystic231's Avatar
    Michigan
    Last time I checked Amazon had the cheapest price for my '02. It was on a OEM Delphi pump, around $246.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  4. #4 Re: Miss Lisa's GTP is dead
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    wow i paid 380 for mine from gm
  1. 1997 dead miss
    By Hosscat in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2009, 02:20 PM
  2. I miss my car!
    By JCG's-GTP in forum Visual/Body Modifications
    Last Post: 04-15-2009, 12:55 AM
  3. I'm going to miss my dealership
    By stkks in forum Off Topic Discussion
    Last Post: 03-14-2009, 03:59 PM
  4. I have a miss. :(
    By Doug_Guilds in forum General Tech Discussion
    Last Post: 09-09-2008, 07:19 PM
