Thread: PO171 case help
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21 Re: PO171 case help
    May 2016
    PA
    BTW,
    1. I forgot to mention that as soon as I connect the sensor to the PCM (while scope connected), It's voltage gets cut in half or more.
    2. The brake booster check valve in GM cars is different from what they call a "universal" valve in almost all store (for about $6-12), get the AC Delco bigger one ($20-35). See pics below, black is OEM while white is cheap napa universal one. The vacuum hose that comes from the manifold to the booster is about double the size on the white valve.
    3. Attached are pics for the final O2 sensor simulator circuit.
  2. #22 Re: PO171 case help
    Nov 2021
    Reading, PA
    I don't have anything to add, but would love to know whereabouts you are. I'd love to have someone like you, to help with the electrical stuff!
  1. '02 GT Coupe PO171 Code
    By gtonut1 in forum Introductions/Noob Questions
    Last Post: 12-01-2016, 10:41 PM
  2. PO171 Found!
    By 02grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2014, 05:59 AM
  3. po171
    By 01GrandPrixTURBOGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-26-2013, 10:33 AM
  4. trouble code po171 bank 1
    By peter in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2012, 01:21 PM
  5. po171 under heavy throttle
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2010, 01:26 PM
