Thread: New member/Part problem
Results 1 to 2 of 2
  1. #1 New member/Part problem
    Dec 2022
    Texas
    Hello all! My name is Robby. I have a 2006 GXP. I was changing the serpentine belt when the tension pulley assembly broke at the top of the spring. Where do we find these parts now that GM has discontinued manufacturing?
  2. #2 Re: New member/Part problem
    St. Louis
    I'd start calling up local parts stores and see if you can order it. Or hit up a few local dealers and see if they have any left. Other than that just keep searching 12596250 on the net and see if one pops up. Often I'll see them on Ebay.
    Worst case hit up a junk yard or 2. IIRC these tensioners were used on any 5.3L FWD car (Monte Carlo, Buick LaCrosse, Grand Prix). In fact you may give car-part.com a try and see if you can find a used one.
  1. New member/Part problem
    By robbymaan in forum Introductions/Noob Questions
    Last Post: 12-11-2022, 03:07 PM
  2. new member with problem
    By mustangcad in forum Introductions/Noob Questions
    Last Post: 03-14-2013, 08:26 PM
  3. New member - 2008 GXP Tranny problem - suggestions?
    By kgf in forum Introductions/Noob Questions
    Last Post: 02-24-2013, 11:12 AM
  4. new member trans problem need help bad
    By 99GTghost in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-13-2011, 09:31 PM
  5. Problem with another member, what should I do???
    By nikkigpgt00 in forum Off Topic Discussion
    Last Post: 04-02-2010, 03:50 PM
