Thread: Oil Leak
Results 1 to 3 of 3
  1. #1 Oil Leak
    Mar 2021
    Michigan
    Hi all, I have a little experience with fixing cars just not much, hence this post. I have an oil leak in my 2006 Base Grand Prix. It looks like it’s coming from the rear of the engine, I had a thought about the oil pump O-Ring just going bad but I don’t know. Under the hood there doesn’t seem to be oil anywhere on top of the engine. Any help would be amazing. I just really don’t know what I’m looking for
  2. #2 Re: Oil Leak
    hangover park IL
    below the power steering pump is a lime green collored roundish electrical connector that goes to the oil pressure sending unit.
    unplug this connector and look for oil inside the connector/terminjals to confirm the sensor seal is blown.
    this is far more common than many other leaks. and it happens often enough that i delete the sensor on my ****
    ~James~ Psychotic Gearhead
  3. #3 Re: Oil Leak
    I usually suggest that you deep clean everything first too. Get some degreaser, oven cleaner or whatever to break down all the grime and oil, wash it off and let it dry. Then get under the car to see where the leak is coming from.
    If it's dripping out constantly then the above is a pretty good bet.
  1. Small coolant leak turned into a large coolant leak
    By DreamerGT in forum General Tech Discussion
    Last Post: 09-23-2016, 11:00 AM
  2. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  3. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  4. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  5. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
