Thread: Has anyone actually tinted outside of rear window???
Results 1 to 2 of 2
  1. #1 Has anyone actually tinted outside of rear window???
    Jan 2021
    Tucson
    I have done a bit of research and I keep seeing a ton of people saying "Don't tint the outside of windows because its exposed to the elements DUH!"... but I have not seen a single video or evidence of someone having tried this. Seems to me like people are just repeating a consensus that has not been properly tested, and since its a *&$#! to remove third brake light for an 01 grand prix GT, which is required to properly tint interior of rear window -- why not tint the exterior of the window? What's the Big deal with tinting the exterior of the rear window??? What environmental factor is external tint exposed to that internal tint is not?
  2. #2 Re: Has anyone actually tinted outside of rear window???
    Scratches, water ... which is basically all it would take over time to remove the tint. Tint needs to be dry.
    If you think removing the 3rd brake light is bad, maybe this helps put it in perspective:
    Trim pop tool for C pillars ~3 min each side
    Remove bottom of seat with hands ~1 min if you milk the job
    Remove rear seat with (IIRC) 19mm and 10 mm nuts then lift up to disengage top clipped in piece ~5 min
    Remove trim clips and slide rear deck out ~3 min
    Around 10-15 minutes is all it should take to have it out. I've removed it on a lot of cars for various reasons (usually tint) and never regretted doing it. One thing to consider is in a lot of states it's technically illegal to tint over the brake light. I've always done it and never been hassled though.
  3. Likes iamteeg liked this post
  1. Front and rear seats, Tinted tail lights
    By Will5600 in forum For Sale - Parts
    Last Post: 08-06-2013, 09:02 PM
  2. Tinted my rear window
    By KawaFord in forum Off Topic Discussion
    Last Post: 05-25-2010, 09:06 PM
  3. Where Can you find tinted rear brake lens on 04+ GP??
    By Redbirds2230 in forum Visual/Body Modifications
    Last Post: 05-11-2010, 08:00 AM
