Thread: What The Heck Are These?
Results 1 to 7 of 7
  1. #1 What The Heck Are These?
    Apr 2020
    CA
    Hey guys!
    I just bought an 06 base Grand Prix for $200 to rebuild, pretty much done and ready to put the engine back in... and for some reason, I can't remember where I pulled these from!
    Also, I cannot seem to find replacement exhaust studs anywhere...
    Would anyone have any ideas? (Digital) beer is on me!
    What The Heck Are These? Attached Images
  2. #2 Re: What The Heck Are These?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    i think the one on the left is the MAP sensor bracket that bolts on the rear top of the LIM
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: What The Heck Are These?
    Apr 2020
    CA
    Thanks! Pretty sure that's it... Also, figured out what the circular thing is (motor mount of some kind).
    I really appreciate it!
  4. #4 Re: What The Heck Are These?
    larger part the bolts to the lim on the left side side of the engine, leads tot he dog bone mount on the rad support. you got the bolts in the wrong side, they go in from the other side, then that part goes over the valve cover pretty tightly. but not touching.
  5. #5 Re: What The Heck Are These?
    looking back at your dog bone, the new engine come from a H body? might be the single upper dog bone they have.
  6. #6 Re: What The Heck Are These?
    Apr 2020
    CA
    Actually, it's just a pull and rebuild, so my engine should be original to this W body.
    Thank you guys for all your help!
    Funnily enough, I'm still trying to figure out the L shaped bracket.
  7. #7 Re: What The Heck Are These?
    St. Louis
    That small bracket is part of the EGR mount. The large bolt with the torx mark in the top goes into the LIM/head right around the middle cylinder in the back. Look close to the injector for cyl #4 and you should see it. Under the fuel rail. Once you lay it back there you should be able to tell where the rest bolt to.
  1. How the heck did I get here?
    By stefunz in forum Introductions/Noob Questions
    Last Post: 09-05-2016, 05:33 PM
  2. What the heck is this??
    By overtimeracing in forum General Tech Discussion
    Last Post: 06-22-2011, 06:26 PM
  3. ICM out, now where the heck is the CPS?
    By clush in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-07-2011, 07:20 PM
  4. What the heck is this?
    By Taz Magister in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2011, 09:23 PM
  5. What the heck is going on???
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2010, 03:51 AM
