Thread: new guy
Results 1 to 13 of 13
  1. #1 new guy
    Dec 2018
    Lehigh Valley, PA
    New guy from eastern PA. 2004 GTP. Just picked it up a week ago, 166K miles. Has a slight misfire under load, but I'll be checking and replacing spark plugs, wires, coils or ICM as needed. I have a feeling the PO put crappy plugs in it and didn't gap them properly. Once it's running as it should, I'll probably start some mods in the spring if I'm not spending all my time getting one of my other projects on the road.
  2. #2 Re: new guy
    Kemmerer, Wyoming
    previous owner might have run lower octane fuel. run a couple tanks of premium through it and see if it goes away.
  3. #3 Re: new guy
    HUDSON
    Change your spark plugs and ignition wires first to see if that helps with the slight misfire under load before changing your coils.
  4. #4 Re: new guy
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Welcome, Friend !
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  5. #5 Re: new guy
    Jun 2018
    Lehigh Valley
    Howdy, neighbor!
    '97 Grand Prix GT Coupe
    '05 Grand Prix GTP Sport Red Metalic SOLD
    '05 Grand Prix GTP Silver
  6. #6 Re: new guy
    Dec 2018
    Lehigh Valley, PA
    I’m halfway through my second tank of premium and it’s not getting any better. And I let it get pretty empty before refills just for that purpose. I took the metal heat shielding off the spark plug boots, still the same. Wires are brand new OEM replacements, plugs are brand new AC Delcos. I’ll pull a few later to see if they’re properly gapped. I got an ICM and coils coming on Tuesday. We’ll see if that does it.
  7. #7 Re: new guy
    what plugs does it have? delco is a broad term. if they are platinum it could the cause of it all. these engine run on iridium plugs, or copper core plugs work best and are dirt cheap at 20 or less for a set of al 104's.
  8. #8 Re: new guy
    Dec 2018
    Lehigh Valley, PA
    Good point, I honestly don’t know until I pull one out to look at the PN. I have a feeling I’m gonna be buying a set of 104’s anyway just because of the modifications I have planned.
  9. #9 Re: new guy
    Dec 2018
    Lehigh Valley, PA
    It was the coils. 2 originals reading just out of spec and one aftermarket reading perfect. Put used original ones on from a low mile 2005 Monte SS sc and the car runs great now.
  10. #10 Re: new guy
    nice find. they dont usually fail. when they do you find a crack in the plastic most of the time.
  11. #11 Re: new guy
    Dec 2018
    Lehigh Valley, PA
    No cracks that I could see. But I figured that’s what it was because it was acting just like my old T Type breaking up under boost.
  12. #12 Re: new guy
    Pennsylvania
    Good to see another PA guy here, Im a little ways from Allentown!
    Sport Edition Kv5 18x8
  13. #13 Re: new guy
    Dec 2018
    Lehigh Valley, PA
    I’m just north of Allentown! Less than 15 minutes from the airport!
