Thread: Worse case scenario? Screwdriver in the ignition.
Results 1 to 12 of 12
  1. #1 Worse case scenario? Screwdriver in the ignition.
    GT Level Member Beelzeboul's Avatar
    Racine
    Im just wondering how wrong this could go.
    I have a troubleshooting post up elsewhere but really wanted a worse case for fear of damaging the ignition or anti theft system.
    symptom:
    Ignition cylinder does not recognize the key to turn the ignition
    Ignition cylinder cannot be turned due to steering wheel lock being engaged
    So my plan as of right now is to hammer a screwdriver into the ignition, turn it to disengage the steering wheel lock and allowing me access to the retaining clip and replacing the ignition cylinder.
    Like I said I just like peace of mind taking this action is not going to result in having to be taken to the dealership to be sorted.
    I'm sorry officer I didnt know I couldn't do that
  2. #2 Re: Worse case scenario? Screwdriver in the ignition.
    try pushing the wheel each way while trying to turn the key?
  3. #3 Re: Worse case scenario? Screwdriver in the ignition.
    Racine
    for sure. the key was severely deteriorated when it was used to tow the car.
    visible rust on it.
    even after several treatments of pb blaster the ignition would not be jostled loose from the steering wheel lock.
    I intend to jack the car up off the front tires and give it one more try before going through with the screwdriver.
    I'm rather convinced that the rusty key damaged the ignition lock.
    Ive tried cleaning the ignition as well slightly tapping the key with a hammer to try to knock anything loose to no avail.
  4. #4 Re: Worse case scenario? Screwdriver in the ignition.
    you can get the key code from the dealership. via the vin #. they can cut it, or you can go to a lock smith type key cutter who can cut with the code.
    now you got a new key to try.
  5. #5 Re: Worse case scenario? Screwdriver in the ignition.
    Racine
    lmao yeah I suppose I should have said,
    This is after having a new key cut to code from the dealership.
  6. #6 Re: Worse case scenario? Screwdriver in the ignition.
    Having only done like one ignition... does the key have to be turned in order to remove the cylinder?
    I know Scott knows this
  7. #7 Re: Worse case scenario? Screwdriver in the ignition.
    yes it does. then push in the small hole up top with a pick and pull the cylinder out.
  8. #8 Re: Worse case scenario? Screwdriver in the ignition.
    Racine
    Yeah I had tried using a paperclip to kind of give it the reach around form the access hole but the key has to be in the on or acc position in order for the retainer clip to line up with the access hole.
    this is where my issues come in with the steering wheel locked I cant remove and replace the ignition cylinder.
    Hence screwdriver to the ignition. It just seems a little scary to take such a destructive action without knowing the possible repercussions.
    I just wanted to make sure this is gonna trigger some no start dealership reset theft system or damage the ignition itself to the point where I need a new column.
  9. #9 Re: Worse case scenario? Screwdriver in the ignition.
    my worry would be you break the column. everything else can be delt with easy.
    in theory you should be able to just turn the knob on the black ignition harness box and fire it up. the key turns the knob on the box.
  10. #10 Re: Worse case scenario? Screwdriver in the ignition.
    Racine
    yeah that what I was thinking, Ill just try to be as gentle as possible.
  11. #11 Re: Worse case scenario? Screwdriver in the ignition.
    SE Level Member smg267's Avatar
    Apr 2016
    killadelphia
    Did you try under the steering wheel the quick release button for the key? I used that button for a year until I finally fixed my ignition switch. To pull the entire ignition switch you need a weird inverted torque key. I had to buy it from Autozone. I personally wouldn't hammer the key.
    99 GTP , 01 Z/28 H/C/I , 05 Hemi Grand Cherokee, 07 Ducati S2r800
  12. #12 Re: Worse case scenario? Screwdriver in the ignition.
    Jul 2010
    Coquitlam,BC,Canada
    Drill out the ignition cylinder.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Replies: 5
    Last Post: 11-22-2012, 01:06 PM
  2. 1995 headlight adjust - female torx screwdriver?
    By tstockma in forum General Tech Discussion
    Last Post: 10-19-2012, 05:48 AM
  3. Geek Alert: Sonic Screwdriver Key Fob?
    By ShadowSwept in forum Audio, Security & Visual Electronics
    Last Post: 08-17-2012, 04:41 AM
  4. Worse MPG?
    By secesh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2011, 08:43 PM
