Thread: Exactly where do those little cupholder springs attach?
Results 1 to 5 of 5
  1. #1 Exactly where do those little cupholder springs attach?
    Aug 2016
    S.F. Bay Area (east bay), California
    These things.
    I'm restoring my wife's 2001 GP GT and I have the springs, I have the cupholder, but I can't figure out exactly how they attach.
    Anyone, anything. . .photo, diagram, anything. Help.
  2. #2 Re: Exactly where do those little cupholder springs attach?
    GrandPrix Junkie
    St. Louis
    There should be a small hole on the bottom of the cupholder where the bent side of the spring attaches. Then it's just a pressure fit for the other end. If you get stuck I have a spare console at home I can look at later tonight.
  3. #3 Re: Exactly where do those little cupholder springs attach?
    Aug 2016
    I've definitely ID'd the holes they go into, I just need a photo of which way `round they go. Strong little buggers, they threaten to break the plastic tab on the cupholder that they go into.
  4. #4 Re: Exactly where do those little cupholder springs attach?
    GrandPrix Junkie
    St. Louis
    Well, my spare console doesn't have the cupholder in it like I thought, and my GP is at the shop getting the hood painted so I can't pull my current one to look. What I do see on my spare is there is a hole on the underside of the bracket. That should be where the 90* part of that spring goes.
  5. #5 Re: Exactly where do those little cupholder springs attach?
    Aug 2016
    I think I can probably figure it out by trial and error, but the springs are handed left and right, and I just need to work out the orientation that the spring goes, and there's different ways the spring can face depending on which spring you use, and I really just need a photo of how one that is together is.
  1. What are these attach to the wire loom for Digital DIC (98 GP)
    By penright in forum Audio, Security & Visual Electronics
    Last Post: 08-07-2014, 09:46 AM
  2. heat shield connects to the...? (and how to attach?)
    By yourTVlies in forum Brakes/Suspension/Chassis
    Last Post: 08-21-2010, 08:25 PM
  3. cupholder/gauges done!!!!!!!!!!!!!!1
    By 00grandam in forum Visual/Body Modifications
    Last Post: 02-14-2010, 02:48 PM
  4. Cupholder Removal?
    By Abrasive in forum General Tech Discussion
    Last Post: 12-10-2008, 11:42 PM
