Thread: Noob & Radiator Cooling Fans
Results 1 to 7 of 7
  1. #1 Noob & Radiator Cooling Fans
    Jun 2017
    NE Ohio
    Hi All,
    We bought new a 1997 GTP 2 door, probably one of the earliest because we took delivery in early July of 1996. The car is still in the family, brother-in-law, and is in great shape. No rust, suspension just gone through & Serpentine belt & pulleys replaced @ 150,000 miles but is in need of some mechanical repair.
    The radiator cooling fans are the immediate problem. GM has quit making the left side and is sketchy on the right. I'm sure that this has come up before & I'm hoping that someone here knows what aftermarket fans will do the job without major changes or where we can purchase original fans.
    Thanks & if I need to post this in another area, please advise,
    Paul, Sandusky Bay, Ohio
  2. #2 Re: Noob & Radiator Cooling Fans
    St. Louis
    Junkyard, Car-Part.com, Ebay, Morad parts are places to get the OE fans from used.
  3. #3 Re: Noob & Radiator Cooling Fans
    GTP Level Member buickman104's Avatar
    NYC
    In about an hour I am about to pull my fan assembly out as the Dorman replacement died under 1 year.
    You might want to go with OEM on this as i HATE doing the same job twice on the same car.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: Noob & Radiator Cooling Fans
    Jun 2017
    NE Ohio
    Thanks FordMan, the links are good & I think I'll hit a couple of junkyards around here. If I can find these, I'll see if I can disassemble and clean them up.
    Paul
  5. #5 Re: Noob & Radiator Cooling Fans
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Welcome to GPF, Friend! Flush out factory Dexcool if you haven't already.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  6. #6 Re: Noob & Radiator Cooling Fans
    Jun 2017
    NE Ohio
    Hi Buickman,
    There are no OEM's available from GM or the other sources I've tried. One side is available but the other is not. If you have a source, I'd appreciate if you'd pass it on. I asked my brother who is a "Mr. Goodwrench" and he said GM is abandoning parts for most of the older cars in the hopes it will sell more new cars. It seems they built these cars to good and they just keep running.
    Paul
  7. #7 Re: Noob & Radiator Cooling Fans
    May 2016
    Rouge Island
    I sent you a PM. Click on "notifications" at the top of home screen. : )
  1. replacement cooling fans and radiator for GXP
    By pdemondo in forum 5.3L V8 (LS4)
    Last Post: 03-06-2016, 06:26 PM
  2. cooling fans
    By GXPrunner06 in forum 5.3L V8 (LS4)
    Last Post: 09-22-2013, 04:16 PM
  3. cooling fans on 90 G.P.
    By TIMS TURBO in forum General Tech Discussion
    Last Post: 05-01-2012, 06:34 AM
  4. cooling fans always run
    By jaxso6 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2011, 08:33 PM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
