Thread: Any benefit to shorter dog bones?
Results 1 to 8 of 8
  1. #1 Any benefit to shorter dog bones?
    SE Level Member smg267's Avatar
    Apr 2016
    killadelphia
    During my weekly trips to the you pull it I found a couple Montanas. My search results have been varied between it's awesome!, and it through off the geometry raise the engine as it blows all the other suspension components off while causing exhaust leaks.
    I'd throw $10 at it as long as it doesn't cause $200 in problems.
    99 GTP , 01 Z/28 H/C/I , 05 Hemi Grand Cherokee, 07 Ducati S2r800
  2. #2 Re: Any benefit to shorter dog bones?
    Me personally, I never saw a reason to do it. The factory length mount are never a problem.
  3. #3 Re: Any benefit to shorter dog bones?
    Apr 2016
    killadelphia
    Thanks for quick reply.
  4. #4 Re: Any benefit to shorter dog bones?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Cosmetics and some people describe a firmer shift or similar feeling.
    The stock ones are fine ..just not the prettiest.
  5. #5 Re: Any benefit to shorter dog bones?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    if your car is substantially lowered, the shorter dogbones can sort of restore the geometry to prevent shimmy / wheel hop
    https://zzperformance.com/3800/shorter-dog-bones.html
    Replace your stock dogbones with these 1" shorter replacements. Shorter dogbones will hold the engine forward, which has a few benefits as shown below.
    Better oil pickup during drag racing
    Removes vibration caused from lowering the car
    Better axle alignment for less HP loss through the shafts
    Increased weight on the front tires for better launching
    Added clearance to sway bar for header and downpipe installs
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. #6 Re: Any benefit to shorter dog bones?
    Apr 2017
    Chicago
    + easier to change the rear spark plugs
  7. #7 Re: Any benefit to shorter dog bones?
    The proper way to correct the axle geometry is to use actual motor mount spacers, the dog bones do not do enough.
  8. #8 Re: Any benefit to shorter dog bones?
    Dec 2012
    troll land
    Dogbones are pointless for 99% of cars. None of the claimed advantages (aside from the plug thing I guess lol) are legitimate. Merely a band aid for if you get vibration after lowering. I've been running a 5" drop with stock dB's 5 years now and have yet to have vibration
  1. Zzp polished shorter billet dog bones
    By Sudden in forum For Sale - Parts
    Last Post: 01-01-2017, 10:27 AM
  2. Plog, cross over, shorter dog bones.
    By Javi in forum For Sale - Parts
    Last Post: 03-21-2014, 08:20 AM
  3. 04+ shorter dog bones
    By sca555 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2010, 11:55 AM
