Thread: Best cat to use with Speed Daddy headers?
Results 1 to 17 of 17
  1. #1 Best cat to use with Speed Daddy headers?
    May 2015
    Joliet, Illinois 60436
    Hey guys, I'm having the hardest time trying to passs emissions ever since I installed speed daddy headers. I got my uncle's shop to weld on some generic cat after installing the headers and no matter what I can't pass emissions. I've got the o2 codes tuned out, but my emissions readiness still says the catalyst is still incomplete. Any recommendations for a good quality cat would be appreciated!
  2. #2 Re: Best cat to use with Speed Daddy headers?
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    What year car?
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  3. #3 Re: Best cat to use with Speed Daddy headers?
    Kemmerer, Wyoming
    if it's a 2001 or later, you have to find a way to disable the cat test diagnostic
  4. #4 Re: Best cat to use with Speed Daddy headers?
    crap, i just looked at your bin the second 1/2 of the 420 code i missed or it didnt take .
    how many miles you put on it so far? it should become ready still cause the o2 codes and tests are not there to tell it to throw the 420 cat code. it just needs to cycle a bunch of times.
  5. #5 Re: Best cat to use with Speed Daddy headers?
    May 2015
    It's a 2001 GTP. And Scotty, I've put 230miles on it so far. I've done the gm drive cycle where you have to put the ac and defroster on for about 2 and a half mins and drive for ten mins. I've done this three separate times from a cold start. I've got everything to say it's emissions ready /except/ for the catalyst and o2 Sensor. I'll post a pic of my emission diagnostic log in a few minutes.
  6. #6 Re: Best cat to use with Speed Daddy headers?
    May 2015
    http://imgur.com/SyzpJvA Here's a pic of my Emissions Readiness s/DTC.
  7. #7 Re: Best cat to use with Speed Daddy headers?
    weren't you having the same issue with the last tuned pcm? my car only shows one 02 sensor, and it also can take a while to become ready, its the up stream o2 you cant delete that one. its the post cat "rear" o2 that gets deleted.
  8. #8 Re: Best cat to use with Speed Daddy headers?
    i just loaded up your bin to a spare pcm, tomorrow after work ill hook my t app up to it and see what your seeing as far as im "ready"
  9. #9 Re: Best cat to use with Speed Daddy headers?
    May 2015
    Honestly I never checked my emissions readiness with my old pcm. Wish I had now lol. I can understand that the cat would take a little while to show its ready, but any idea why the o2 wouldnt ready by this point? After 230 miles I'm sort of losing hope that it'll fix itself with more miles. I'll go give it another try later on tonight and see if anything changes, but I won't hold my breath.
  10. #10 Re: Best cat to use with Speed Daddy headers?
    May 2015
    And thanks, you're the man.
  11. #11 Re: Best cat to use with Speed Daddy headers?
    May 2015
    Also heres a look at my o2 sensor voltages http://imgur.com/RnQnNer. They fluctuated as I drove, within .05 or so. As far as I know they look fine, but figured I'd present that information. Also here a some vehicle test results http://imgur.com/CqoyXhn. The code TID: $05 CID:$0a was not working properly, infact it was the only code that wasnt working properly. Its the rich to lean sensor switch and it hasnt calculated anything at all. Any ideas on what might be the cause? I'm thinking this is maybe one of the reasons why o2 wont show its ready yet. But I havent got a clue. If theres any more information needed I can try to provide more.
  12. #12 Re: Best cat to use with Speed Daddy headers?
    the up stream o2 should be dancing up and down with its volts, .1 to .8 over and over and over. pretty sure thats your switching time. so you might need a new o2. is this the stock o2 your still using?
  13. #13 Re: Best cat to use with Speed Daddy headers?
    May 2015
    I'll go take a look and see if it fluctuates like you said. And yes it's a stock sensor, so its likely due for replacement. I'll order one from rock auto and keep you guys updated.
  14. #14 Re: Best cat to use with Speed Daddy headers?
    May 2015
    Sorry I was mistaken about the whole o2 voltages. The upstream and downstream o2s both fluctuated based on how much gas I gave it. I seen values as low as .2 to values as high as .9. So I'm not confident that these are my problem, but the new o2 is on its way.
  15. #15 Re: Best cat to use with Speed Daddy headers?
    if its sitting at one voltage when at idle, the o2 is lazy. at idle, it should dance up and down. it should always be on the move really.
  16. #16 Re: Best cat to use with Speed Daddy headers?
    May 2015
    So I've put a few hundred miles on the car after the new o2 install and still my o2 and car say they're not ready. So now I'm convinced this something that throwing parts at just won't fix. Scotty, you think you can check my pcm out and see if there's anything funky going on? If not, then I'm about ready to just call this car a lost cost and move on.
  17. #17 Re: Best cat to use with Speed Daddy headers?
    send it over, ill go over it again. and ship it back for free.
  1. Used Speed Daddy Headers
    By Impala131 in forum For Sale - Parts
    Last Post: 11-06-2016, 07:12 PM
  2. WTT Speed daddy headers (new) for PS3
    By Montypr20 in forum Wanted To Trade
    Last Post: 01-07-2015, 12:43 PM
  3. Speed daddy headers
    By GrandPrix06GT in forum Wanted To Buy - Parts
    Last Post: 12-02-2014, 05:07 AM
  4. speed daddy headers
    By redlinepontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 07:54 PM
  5. speed daddy headers
    By sic40th in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 05:07 PM
