Thread: Will an ecu from other years work on an 02 grand prix gtp?
Results 1 to 3 of 3
  1. #1 Will an ecu from other years work on an 02 grand prix gtp?
    Apr 2017
    lakewood
    hey all,
    I am helping a friend with his 2002 grand prix GTP. we are trying to find a replacement ecu ASAP. I found one locally from a 1998 grand prix gtp. Are the ECUs interchangeable?
  2. #2 Re: Will an ecu from other years work on an 02 grand prix gtp?
    May 2008
    Schuyler, NE
    98-02 will usually be interchangeable.
  3. #3 Re: Will an ecu from other years work on an 02 grand prix gtp?
    the maf file is not the same. as the maf part # changed. will it run? yes, but maybe not as well as it should. if the tb and maf are there off the 98 maybe snag it too.
    definitely need to do a security learn. key to run for 10 minutes, off for less then 5 seconds and back to run. do this 3 times. 4 th time you turn the key it will crank and fire up.
  1. Replies: 2
    Last Post: 05-15-2016, 05:42 PM
  2. 2002 Grand Prix GT - Compatible Door Years???
    By TwinLakeGrandPrix in forum General Grand Prix Discussion
    Last Post: 07-23-2014, 12:14 PM
  3. 97 Grand Prix, what years are parts interchangeable
    By louisville in forum General Grand Prix Discussion
    Last Post: 05-13-2013, 10:19 PM
  4. What years of 3800 will work in an '01?
    By binkerton in forum Engine
    Last Post: 03-04-2013, 12:24 PM
  5. Replies: 3
    Last Post: 03-01-2013, 08:37 PM
