Thread: Good brakes?
Results 1 to 9 of 9
  1. #1 Good brakes?
    SE Level Member Felix's Avatar
    Jul 2016
    Getting new rotors/pads, maybe calipers. Was wondering what your guys opinion is. Looking at either https://www.r1concepts.com/details/p...P_Sedan_4-Door or this one from rockauto http://www.rockauto.com/en/moreinfo....382521&jsn=423
  2. #2 Re: Good brakes?
    if your up for new calipers upgrade to f bodys for the fronts, i love my R1 e line with scorched ceramic pads. ill never buy anything else from now on.
  3. #3 Re: Good brakes?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    I bought R1's on Scott and others' recommendation. They're very good so far.
    I also put on four calipers from PowerStop (staying with my stock 11.7" rotors). Also very good, but the powder coating leaves a little to be desired. Mine came lightly greased. I put a dab (not that kind of dab) in each caliper pin.
  4. #4 Re: Good brakes?
    Jul 2016
    Hmm, i'll get the R1 rotors/pads for now. Do the F-body calipers bolt right up?
  5. #5 Re: Good brakes?
  6. #6 Re: Good brakes?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    If you want a simple upgrade, go to RockAuto and get the Olds Intrigue JA9 upgrade kit. This will put 12" rotors on the front with stock calipers. You'll get new calipers, caliper brackets and rotors, and pads.
    http://www.rockauto.com/en/moreinfo....sn=437&jsn=437
    or piece together your own with the rotors and bracket piece parts.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  7. #7 Re: Good brakes?
    Nov 2011
    NY
    Get the F-Body powder coated calipers from Rock Auto, coupled with R1 Rotors and some premium ceramic pads and you'll be good. Replace the brake lines too with Goodrich SS lines and you'll love it!
    Enjoy!
  8. #8 Re: Good brakes?
    Feb 2016
    Utah
    First off, I have no relationship with the company. That said, please look at FrozenRotors.com. This company cold-soaks brake rotors in liquid nitrogen, which reduces warping. I learned this lesson with my Ford Excursion. I was changing front rotors every 10-12K miles, until I got fed up. When I installed the frozen rotors, I went from 40K to 90K miles before they finally warped. Needless to say, the next set was also frozen rotors. I just installed them on my 04 GTP Comp Group. They may not be needed on the GP like they are on the Excursion, but to me it is worth the extra cost (about $100 each over AZ prices).
  9. #9 Re: Good brakes?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    I've had great luck with Raybestos Advanced tech rotors, those things have held up to some intense abuse, and I haven't felt, seen, or heard anything from them.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  1. Good deal on brakes?
    By RonsGTP in forum Brakes/Suspension/Chassis
    Last Post: 10-07-2016, 01:09 AM
  2. Brembo brakes or f-body brakes? Any other choices?
    By LAST2DOOR in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2013, 10:37 PM
  3. Good time to swap out brakes?
    By gwizlo in forum Brakes/Suspension/Chassis
    Last Post: 10-21-2009, 10:58 AM
  4. is this a good deal for brakes?
    By 2000GTP in forum Brakes/Suspension/Chassis
    Last Post: 02-21-2009, 09:51 PM
  5. f body brakes good?
    Last Post: 01-25-2009, 12:45 PM
