Thread: Hello
Results 1 to 3 of 3
  1. #1 Hello
    Feb 2017
    Pheonix
    Hi everyone, just decided to buy a 06 grand prix with 120k mile. I test-drove it before, runs smoothly. Is there any specific common problem that I have to pay attention to?
    Thank you. Very glad to be one of the family.
  2. #2 Re: Hello
    GrandPrix Junkie
    St. Louis
    Welcome. Plenty of knowledge on here. If you don't know the last time the trans fluid was changed then I'd drop the pan, install a trans-go shift kit, change the filter and refill with new fluid. At 120K I'd think about changing the plugs/wires (if they are original), remove and clean the throttle body (the drive by wire ones like to cause issues when they get dirty). Other than that maybe new struts if original, and check the front end for any loose bits (tie-rods, sway links, etc.) Just normal maint stuff.
  3. #3 Re: Hello
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Add to that, a coolant flush/swap if it still has orange Dexcool. Check air filter, serpentine belt, radiator & heater hoses. Clean MAF (mass airflow) sensor with CRC MAF cleaner (super easy, maf is between air filter & throttle body, just spray it), all of these are low $$ things...Oh, and Welcome...Enjoy...good luck....E.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
