Thread: Engine Cranks, no start, Service Engine Light on at all times
Results 1 to 5 of 5
  1. #1 Engine Cranks, no start, Service Engine Light on at all times
    Jan 2017
    KY
    I've got an interesting problem. I've got a 2004 Grand Prix that just ran great. One morning about a week ago I went out to start it, and I noticed that the Check Engine Light came on immediately, and stayed on while I cranked the engine. Normally that light does not stay on once the key is turned. The car won't start, although it cranks well. No fuel or fire either.
    I've checked the PCM fuse, fuel pump fuse, and made sure everything was plugged in. I thought it might be the computer, since absolutely nothing would function, so I got another one, but the same thing happens. I've returned the computer, and I've got a scan tool on the way, but I wanted to see if anyone else had this type of issue. It's like the whole system shut down, and nothing will operate. All other electronics operate normally.
    Any help is appreciated. Thanks!
  2. #2 Re: Engine Cranks, no start, Service Engine Light on at all times
    check for fuel pressure at the rail. key to on there should be pressure.
  3. #3 Re: Engine Cranks, no start, Service Engine Light on at all times
    Dec 2016
    TN
    Idk about supercharged motors but if you used starter fluid you could narrow if it is a spark or fuel issue
  4. #4 Re: Engine Cranks, no start, Service Engine Light on at all times
    hangover park IL
    probably the ignition switch. check for +12v at the injector connectors with KOEO, you should have power, KOEO you shouldn't. problem is that the relay doesn't get power to turn on power to the ign/fuel/etc because of a bad switch, even though it will crank over. since you have no fuel/fuel pump/ign, start there
    ~James~ Psychotic Gearhead
  5. #5 Re: Engine Cranks, no start, Service Engine Light on at all times
    Jan 2017
    KY
    Thanks everyone! Appreciate the advice.
  1. Replies: 6
    Last Post: 07-20-2021, 09:27 PM
  2. Engine cranks, but won't start *Might be solved*
    By zipper in forum General Tech Discussion
    Last Post: 05-09-2015, 09:56 PM
  3. Engine cranks but won't start
    By PaulGoldstraw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2012, 07:15 PM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Engine Cranks but Will not Start
    By rockytop104 in forum Introductions/Noob Questions
    Last Post: 10-04-2010, 08:21 PM
