I have had nothing but trouble finding the freeze plugs that goes in the front top of the intake manifold and the pulley bracket on top. Part store just cant find them, cant say what size they are. Need help with this info. Thanks Miles Truex
are you referring to the coolant bypass elbows?
One goes from the tensioner bracket to the intake and the other goes from the tensioner bracket to the timing cover.
There is no freeze plug / Welsh plug in our lower intake.
The coolant elbows are available in any Dorman/HELP isle of a parts store
Are you talking about these?
If so check this thread out http://www.grandprixforums.net/threads/67181-Aluminum-coolant-elbow
if we are talking elbows your 97 has one plastic replaceable elbow, the lower one is part of the alt bracket.
read the bottom of post one. http://www.grandprixforums.net/threa...coolant-elbows
Thank you all for the information regarding the Elbows. Even the guys at the part store was unable to help me, thanks again. I have replaced both at they are working great. I now have a new problem. One of the rear freeze plugs has come out. It is one that is at the rear towards the firewall. I can see it from underneath with a light. there is also what looks to be a oil sending unit and wire between two of the freeze plugs. Is there any way to put back it this freeze plug without taking the motor our. I love this little car but all the little things the person that had it before neglected are needing fixed. Thanks for any help you can provide, and thanks again for the Elbow info. Miles Truex
if you can reach and clean the hole of the rotted plug, you can put a block heater in the hole. or pull the engine.
theres only a kr sensor in the block its where it lives. nothing came out but coolant.
Or how hard it is to remove the Exhaust Manifold ? Thanks Miles
it can come off. un bolt the cross over, the dp and then un bolt it from the head. the cross over and dp bolts might just break, so be ready to drill th eold studs out and have new nuts and bolts ready.
