Just picked this up as a D/D:
https://www.dropbox.com/sh/e26slmxqc...ZWxdFBFMa?dl=0
Aside from a hitch through the front bumper and a mark on the side of the rear bumper, it doesn't seem to be in to bad of a shape. The first thing I need to do is fix the TCC module. It's throwing a code which is turning the check engine light on. Is there a "how to" for this? If not, I'll do one when I replace it. Other plans are to repair/replace the front headlight buckets (really fogged up) and fix/replace the front bumper. Is their anything else I should check/be looking out for on this car? Thanks in advance for any info you can provide and looking forward to getting to know this car!
Other Pontiac in the stable is a a heavily modified '06 GTO that started out as a D/D and slowly turning into a weekend/track car.
Tim
Severn, MD
