Thread: '02 GT Coupe PO171 Code
Results 1 to 4 of 4
  1. #1 '02 GT Coupe PO171 Code
    Dec 2016
    washougal, WA
    I am new here, thanks for the add.
    My GP stalled and died, I had good fuel pressure and it would run above 2000 RPM. Tried to make a run for home but went 2 miles then only WOT. Had it towed home and scanned got MAF was out of limits. Changed that and it fired right up, 2 days later I get Lean bank 1 PO171. Cleared it and it came back in 10 miles. No leaks detected with carb cleaner and it runs very well, no problems at all. Could be O'2 but want some in out as to what else it might be.
    Thank you.
  2. #2 Re: '02 GT Coupe PO171 Code
    I'd smoke test it to see a vacuum leak.
    Lots of time the carb/brake cleaner trick won't find everything.
  3. #3 Re: '02 GT Coupe PO171 Code
    Dec 2016
    washougal, WA
    [QUOTE=Fivefingerdeathpunch;1454856]I'd smoke test it to see a vacuum leak.
  4. #4 Re: '02 GT Coupe PO171 Code
    Dec 2016
    washougal, WA
    Thanks I will see if I can do that myself or have it done.
  1. 97 Grand Prix GT po171 code and abs light
    By Jonarin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-08-2014, 07:03 AM
  2. PO171 Found!
    By 02grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2014, 05:59 AM
  3. po171
    By 01GrandPrixTURBOGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-26-2013, 10:33 AM
  4. trouble code po171 bank 1
    By peter in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2012, 01:21 PM
  5. po171 under heavy throttle
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2010, 01:26 PM
