Thread: newbie
Results 1 to 6 of 6
  1. #1 newbie
    Aug 2016
    united states
    Recently purchased 98 gp gt.
    looking for thread/info about radio removal and replacement. Is it a nightmare for
    a novice to attempt?
    regards,
    Tom
  2. #2 Re: newbie
    Aug 2016
    CT/RI Border
    Do you have steering wheel controls? Does the car have theft lock enabled? IIRC you can get and adapter for the hands free, and theft lock is a pain.
    Following advice is for the base sound system.
    Buy harness/antenna adapters, the dash adapter plate and its not bad. Honestly its more tedious to tear down the dash than remove/install the head unit. Biggest issue will be theft lock, if a code has been set and you don't know it, you can Google theft lock, there is a procedure to get a code from the radio and a phone number to call to get the unlock code.
    I wholeheartedly recommend Alpine head units, I had the Mech-less Bluetooth unit in my 99 worked amazingly. Though if you are updating your head unit speakers should be short listed as the OEM ones are really bad.
  3. #3 Re: newbie
    Aug 2016
    united states
    yes, do have audio steering controls.
    thanks for the follow up
  4. #4 Re: newbie
    Aug 2016
    united states
    what do you recommend as I am revising the entire unit with aftermarket audio.
  5. #5 Re: newbie
    Aug 2016
    CT/RI Border
    Depends on what you have to spend. For an intro level set I am a fan of Alpine Type S, with a Bluetooth head unit. That said, once you start getting to audiophile levels of clarity, Alpine falls off.
    Honestly a good head unit doesn't even really need an amp for every day average volume, and if you want a sub for enjoyment and not missing off the neighbors a single or dual 10s is all you really need.
    Sent from my ASUS_Z00TD using Tapatalk
  6. #6 Re: newbie
    Aug 2016
    united states
    Thanks for the guidance and suggestions.
  1. Newbie
    By MWO2228 in forum Introductions/Noob Questions
    Last Post: 04-15-2012, 09:25 AM
  2. newbie
    By tierce86 in forum Introductions/Noob Questions
    Last Post: 03-15-2012, 02:25 PM
  3. The Newbie
    By 08 grand Prix Driver in forum Introductions/Noob Questions
    Last Post: 03-10-2010, 12:17 PM
  4. Newbie looking for GXP help
    By jstevanus in forum Introductions/Noob Questions
    Last Post: 02-08-2010, 11:23 PM
  5. newbie
    By JESSEGOTTA GP GT in forum Introductions/Noob Questions
    Last Post: 12-07-2009, 11:27 PM
