Thread: Bleed brakes
Results 1 to 3 of 3
  1. #1 Bleed brakes
    Mar 2016
    Bridgeport
    Hey guys quick question, I'm doing the calipers on my gxp and I need to know which way the the front caliper bleeder goes, does it go towards the top or the bottom of the caliper? I think I may have mixed up which side each caliper is. I know it should be printed on the caliper but I can't make it out. Thanks
  2. #2 Re: Bleed brakes
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  3. #3 Re: Bleed brakes
    It has to be on the top, otherwise air will always be trapped.
  1. Bleed screw opened by itself!?!?!?!!!
    By 04gtpnoob in forum 04+ Specifics
    Last Post: 03-24-2016, 10:22 PM
  2. Delco VI ABS Braking System Problems/Trying to bleed rear brakes on a Pre-Gen
    By SpecialEdition01 in forum Brakes/Suspension/Chassis
    Last Post: 07-14-2013, 06:34 PM
  3. How long to bleed the coolant.
    By chevyy1212 in forum General Tech Discussion
    Last Post: 01-16-2011, 09:40 PM
  4. How do you bleed the master cylinder?
    By corsagtp in forum Brakes/Suspension/Chassis
    Last Post: 08-18-2010, 05:30 PM
  5. Help quick! Coolant bleed?
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2009, 08:14 PM
