Thread: Rubber or metal water pump gasket on '04 Comp G
Results 1 to 5 of 5
  1. #1 Rubber or metal water pump gasket on '04 Comp G
    Mar 2016
    Rochester, NY
    Advance auto had both, not sure which is preferred so tell me which one to use and which to return
  2. #2 Re: Rubber or metal water pump gasket on '04 Comp G
    ive used em both, really dont matter. install both dry, no rtv needed. make sure the timing cover is clean. thread sealant on the 4 long bolts.
  3. #3 Re: Rubber or metal water pump gasket on '04 Comp G
    Mar 2016
    Rochester, NY
    While I'm at it, should I use rtv on the lower intake gasket or just 4 dabs of it in the corners like the little paper in the box said? yes its a metal gasket
  4. #4 Re: Rubber or metal water pump gasket on '04 Comp G
    smear a dab in all 4 corners, then install the gaskets, then another dab on top of the gaskets in the 4 corners. thats it. dont forget new elbows.
  5. #5 Re: Rubber or metal water pump gasket on '04 Comp G
    Mar 2016
    Rochester, NY
    awesome thanks! easy enough haha
  1. Zzp l67 rubber throttle body gasket
    By snj111795 in forum Introductions/Noob Questions
    Last Post: 09-21-2015, 08:20 AM
  2. Can you reuse metal LIM gasket??
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2014, 02:19 PM
  3. Bad water pump,wrong water pump? 2002 GTP
    By R STARR in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 06:47 AM
  4. What year did the factory start using the metal frame intake gasket?
    By Gasnmyveins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2012, 12:32 PM
  5. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
