Thread: Help! Subframe rear Bolt
Results 1 to 4 of 4
  1. #1 Help! Subframe rear Bolt
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    I need some help trying to find a new subframe bolt. Heard a rattle in front end, jacked it up and saw the the rear sub frame bolt is totally gone. I have already gone to JY. Grab the frist Grand Prix rear sub frame bolt i could find. thinking that all of them will be the same. not my case. Or i have bigger issues. trying to find a new one for my car but not having any luck online. I'll even take the whole bushing kit, but all i can find is the front. I need rear.
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  2. #2 Re: Help! Subframe rear Bolt
    St. Louis
    Check with a dealer?
  3. #3 Re: Help! Subframe rear Bolt
    Apr 2014
    Chicopee,MA
    No. just did this all tonite. Maybe if no luck i will try there.
  4. #4 Re: Help! Subframe rear Bolt
    Apr 2014
    Chicopee,MA
    wentoo the godam YD AAGIAN!!!!
    found it, 18mm
  1. aluminum rear subframe
    By BOOGIEMAN in forum Brakes/Suspension/Chassis
    Last Post: 01-13-2015, 11:09 AM
  2. Size bolt stud for FRONT control arm to subframe?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 06-01-2013, 04:19 PM
  3. tricks to rear subframe bushings?
    By Vegas~Blown in forum General Tech Discussion
    Last Post: 04-22-2013, 07:02 PM
