Thread: CS144 Alternator Upgrade
Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
  1. #41 Re: CS144 Alternator Upgrade
    Buffalo
    Booba if you ever want to sell me a pre-made wire kit let me know. I'm running out time trying to source wire , terminal ends with the correct size holes , the mesh shrink wrap over the wire casing , etc
  2. #42 Re: CS144 Alternator Upgrade
    Feb 2013
    Missouri
    This isn't the cheapest stuff, really. Not all that bad though. That was $12.87 to make, a little over 3 foot of wire at $3 a foot (I know i can get it cheaper) and 4 terminals at $.75 each. Once I get everything done I'll have a better idea on what's needed. I don't make a new starter wire because I don't see the point. A clean and well connected factory wire does just fine. I crimped and soldered so they aren't the most flexible towards the ends:
  3. #43 Re: CS144 Alternator Upgrade
    Buffalo
    Looks nice. This is what I bought years ago for my other car. I didn't have the patience to source it all out.
  4. #44 Re: CS144 Alternator Upgrade
    Feb 2013
    Missouri
    That does look good. I thought about a fuse, I might still add one, but I'd have to figure where to mount it with the stereo's fuses. For now I'm gonna pursue the whole 7\8" chain thing. I have an eager machinist that can modify 4T40E gears for the 4T65E, just gotta have him make a set for me first to figure out pricing.
  5. #45 Re: CS144 Alternator Upgrade
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    So my question is, will the 05 Buick Lesabre Denso Hairpin alternator work with a 04 GP w/ the stock bracket? I am looking to upgrade the charging system slightly.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  6. #46 Re: CS144 Alternator Upgrade
    Feb 2013
    Missouri
    That's a good question. I don't know anyone with an 05+ around me, but I can look into it on the interwebz and see what I come up with. I'm stuck at work for now and I'm off all next week, so I'll see what I can't dig up.
  7. #47 Re: CS144 Alternator Upgrade
    Stock bracket no.. You'll still need to go with the fbody tensioner.
    04 Comp G.
  8. #48 Re: CS144 Alternator Upgrade
    Atlanta, GA
    Okay so I can run a 99+ F body bracket with the CS144 for a 2004. Sounds like an awesome upgrade.
  9. #49 Re: CS144 Alternator Upgrade
    Yup
    04 Comp G.
  10. #50 Re: CS144 Alternator Upgrade
    Feb 2013
    Missouri
    My bad. I swear he said 05 GP. Yea, for the 04 the swap is the same as the first post. 05+ is where it gets a little hazy thanks to the current sensor.
  11. #51 Re: CS144 Alternator Upgrade
    GT Level Member chrishova's Avatar
    Norfolk, Virginia, United States
    Just get his bracket http://store.alternatorparts.com/a50...n-bracket.aspx
    I did it a few years ago and I've had no problems, I ran an AD244 and a CS130 and a CS 144. You have to shave 1/2'' off one of the mounting feet closest to the front bumper, but that's it! I recommend Excessive Amperage alternators, or Jimmie Hanna in Virginia Beach, Va.
  12. #52 Re: CS144 Alternator Upgrade
    This is a bottom view with an AD244 while the belt tensioner is off, you need to sawzall 1/2'' off the alt., COVER all the alt so shavings don't get into the alt!
  13. #53 Re: CS144 Alternator Upgrade
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    So I know that this thread is old, but I figured I'd post here instead of staring a new thread.
    I just competed this upgrade on my 2002 pontiac grand prix gt and the lesabre belt is very loose and sqeaks with new belt and tensioner. Should I try the stock belt?
    Also, the battery light is on and throwing codes for alternator output, but I'm getting 14.2v output and battery is charging fine.
    Any advice would be appreciated!
  14. #54 Re: CS144 Alternator Upgrade
    Is the pulley on the alternator smaller? If so, you would need a smaller belt. I just took my belt to the parts store and asked the for oe that was an inch or two shorter. That might do it, you could be having belt slipping problems. Did your new alt have a 4 pin oval plug? If not, that would trigger that light.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
  15. #55 Re: CS144 Alternator Upgrade
    Aug 2017
    Raytown, MO
    I'll have to check the size, but it's the stock 1998 lesabre alternator pulley size. Should I go with something smaller? I compared it to the stock gp pulley and it's identical. Should I be using the stock gp belt instead of the lesabre then? I know the camaro's is too big.
    I'm using stock lesabre plug with 4 pins and two wires. Sense wire to fuse box and other to stock ecu red.
  16. #56 Re: CS144 Alternator Upgrade
    Yes, check the belt sizes and try for a shorter belt
  17. #57 Re: CS144 Alternator Upgrade
    Aug 2017
    Raytown, MO
    Here's the plug I'm using, came off a 1999 buick lesabre if I remember correctly:
    Looking at it, I'm finding cables like this: http://www.autozone.com/electrical-a.../342423_0_8905
    and some with four wires! Which ones do I need, and is this the wrong connector? Will I burn something down using this?
  18. #58 Re: CS144 Alternator Upgrade
    hangover park IL
    not all of the full size GM's used all 4, one is pcm field control, one is remote V sensing, another is wired to the battery temp thermistor on the G bodies with under rear seat battery's 4th isn't used but on other models with the 130
    ~James~ Psychotic Gearhead
  19. #59 Re: CS144 Alternator Upgrade
    Aug 2017
    Raytown, MO
    Thanks turbocharged400sbc. Turns out that the 99 buick lesabre CS144s uses ignition field sense to an indicator light instead of our hookup that uses the pcm and class 2 data to monitor and activate charging. I unfortunately ended up burning out my voltage regulator before I realized this, but the "F" wire goes to the ignition wire (pink wire under driver's side dash) connected with a 200 Ohm resistor and a 10 amp fuse. Eventually I'll run an indicator light in parallel to the resistor so I have a charge light again, but that would involve me caring about having a charge light...
    Good news is that everything works perfect, but I had to fry an alternator to find out... hope this helps someone!
  1. 04+ HUD, HD Trans Upgrade and ZZP Alternator Relocation
    By Explicit_Spade in forum For Sale - Parts
    Last Post: 11-14-2013, 06:13 PM
  2. I think I need a new alternator
    By acidcrashdburnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2012, 07:29 PM
  3. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  4. alternator
    By Goldberg07 in forum General Tech Discussion
    Last Post: 07-13-2011, 03:31 PM
